Suggestions for shortening a high tensile cap screw
Postby Adoom » Mon May 16, 2011 4:36 pm
So I have had to replace some rocker shaft retaining bolts in the head of THE STARVIA!! with cap screws(allen bolts).
I damaged one of the originals when removing it and cannot easily find an exact replacement.
But to get the correct length shank(the unthreaded bit) on the bolt, I have had to get ones that are too long.
I need to shorten the bolts.
They are M8.
They are only tightened up to 22Nm.
The method I am thinking of using is to first wind a nut(or a Die if I have one) on before cutting it.
Suggestions for shortening said bolts....?
Adoom
Re: Suggestions for shortening a high tensile cap screw
Postby Malcolm » Mon May 16, 2011 4:47 pm
That's a pretty safe way to go. Whenever I shorten a bolt I just cut it, use a bench grinder or linisher to square off the end and then give it a small chamfer to help lead in to the thread. Then just run the end under a wire wheel to clean the burrs out of the thread at the end
Postby Quint » Mon May 16, 2011 5:00 pm
Malcolm wrote: Whenever I shorten a bolt I just cut it, use a bench grinder or linisher to square off the end and then give it a small chamfer to help lead in to the thread. Then just run the end under a wire wheel to clean the burrs out of the thread at the end
Can be done with a hacksaw and a file if thats all you've got. Really easy and a good little trick to get under your belt.
Quint
Postby Stott69 » Mon May 16, 2011 9:14 pm
why not extract the broken end?
Image jzs147 Aristo money pit
Stott69
Postby eskimo » Mon May 16, 2011 9:37 pm
Quint wrote:Can be done with a hacksaw and a file if thats all you've got. Really easy and a good little trick to get under your belt.
Have done this many a time with cap screws, works a treat
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby gt4dude » Mon May 16, 2011 9:46 pm
On another note, Anyone sell pre-washered cap screws? Like standard car bolts where the washer stays on the bolt
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby MAGN1T » Mon May 16, 2011 10:21 pm
gt4dude wrote:On another note, Anyone sell pre-washered cap screws? Like standard car bolts where the washer stays on the bolt
Pick a part.
They've got just about everything.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Adoom » Mon May 16, 2011 11:41 pm
Stott69 wrote:why not extract the broken end?
You are confused.
The original bolts are 25mm long with about 10mm of shank.
The only cap screws I could get with 10mm shank are about 40mm long.
So I need to make the cap screws the same length as the original bolts.
Adoom
Postby Truenotch » Tue May 17, 2011 2:03 am
Sounds like you have the right plan anyway. I usually wind a nut on, make a clean cut with angle grinder or hacksaw, clean up and wind the nut in/out a few times to clean the threads.
Truenotch
Postby blindnz » Tue May 17, 2011 8:45 am
The 4age 16v ones are a bitch, the ones that go through the rocker cover. its like a bolt with another thread that goes through to hold the rocker cover on.
These are not fun to snap
blindnz
Postby Adoom » Tue May 17, 2011 10:17 am
Image[/img]
Adoom
Postby Bazda » Tue May 17, 2011 5:04 pm
If its a bolt holding a rocker shaft id just to buy an original item from Nissan.
Postby Adoom » Tue May 17, 2011 5:55 pm
Bazda wrote:If its a bolt holding a rocker shaft id just to buy an original item from Nissan.
According to the nissan parts thingy software, that bolt is only from the CA16/18/20 SOHC engine(NOT the DET) and they stopped making it in 1986 I think. The engine was not exactly uber common. I had to get a bit of coolant hose for it and that was EX japan.
Adoom
