So I have had to replace some rocker shaft retaining bolts in the head of THE STARVIA!! with cap screws(allen bolts).
I damaged one of the originals when removing it and cannot easily find an exact replacement.
But to get the correct length shank(the unthreaded bit) on the bolt, I have had to get ones that are too long.
I need to shorten the bolts.
They are M8.
They are only tightened up to 22Nm.
The method I am thinking of using is to first wind a nut(or a Die if I have one) on before cutting it.
Suggestions for shortening said bolts....?
