After finding this stolen photo it shows you that the belt after removing the A/C pump will have to run underneath the tensioner/idler.
It would be much appreciated if someone would possibly know where I could find this correct tensioner.
touge_ae101 wrote:just get the right length belt that everyone uses and just tension it by tightening the bolts on the powersteering bracket. works mint.
Lloyd wrote:Or just get a ribbed pulley from another toyota and run the belt around the bottom of it. Or leave the AC pump there
rollaholic wrote:if you think fan belts are expensive, make sure you are seated for the price of o2 sensors
