Truenotch wrote:Club4ag has all of your answers
http://club4ag.com/faq_and_tech_pages/E ... 0Codes.htm
But try new plugs first, it's always a good place to start. Also check for vacuum leaks and anything else that might be giving the ECU a bung reading. I had similar issues for a long time because a previous owner had removed an economy gauge without blocking off the line.
QikStarlie wrote:is worth trying another ecu if above ideas fail. have had a faulty smallport ecu cause same symptoms. tried everything. then changed ecu. boom, problem gone
rollaholic wrote:pretty sure i still have one chief if you get stuck
when its running like poos, is it misfiring? or has it just got no go.
RedMist wrote:Sounds like it's getting no TPS input. Computer thinks it's got no throttle so adds no fuel. Misfire is a lean misfire. I'd be very wary of running it as is. You'll be running extremely lean mixtures.
I'd check TPS wiring, TPS and computer.
Does the smallport also run MAP? I'm getting so rusty on my 4age stuff.
Users browsing this forum: Bing [Bot] and 4 guests
