Smallport 4age issues...
Postby doin donuts » Thu Jul 21, 2011 5:55 pm
Hey all.
I have a smallport 4age in my ae85 and im having issues,it splutters and struggles below 3000rpm but goes fine after that,Iv changed the dizzy cap but any other ideas?gonna have a go at the plugs tonight tonsee what they are like.
Thanks all
4agze ae86 trueno...let the fun begin!!
doin donuts
Postby LEAKER » Thu Jul 21, 2011 6:16 pm
Any fault codes?
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby doin donuts » Thu Jul 21, 2011 6:18 pm
Don't know how to check it?it's in an ae85
doin donuts
Postby rollaholic » Thu Jul 21, 2011 6:20 pm
who did ya wiring?
if it was nic, ask him what he did with the diagnostics plug :)
i presume you are using all smallport parts - ecu etc
Postby doin donuts » Thu Jul 21, 2011 6:29 pm
Yeah he did and know where the plug is but how do I actually check for codes etc?what do I use?
doin donuts
Postby Truenotch » Thu Jul 21, 2011 7:16 pm
Club4ag has all of your answers
http://club4ag.com/faq_and_tech_pages/E ... 0Codes.htm
But try new plugs first, it's always a good place to start. Also check for vacuum leaks and anything else that might be giving the ECU a bung reading. I had similar issues for a long time because a previous owner had removed an economy gauge without blocking off the line.
Truenotch
Postby doin donuts » Thu Jul 21, 2011 7:25 pm
Truenotch wrote:Club4ag has all of your answers
Ok sweet thanks man il try plugs first then go from there.
doin donuts
Postby QikStarlie » Thu Jul 21, 2011 8:06 pm
is worth trying another ecu if above ideas fail. have had a faulty smallport ecu cause same symptoms. tried everything. then changed ecu. boom, problem gone
QikStarlie
Postby doin donuts » Thu Jul 21, 2011 8:56 pm
QikStarlie wrote:is worth trying another ecu if above ideas fail. have had a faulty smallport ecu cause same symptoms. tried everything. then changed ecu. boom, problem gone
Ok il give that a go after if not fixed.need to find another smallport ecu
doin donuts
Postby rollaholic » Fri Jul 22, 2011 8:09 am
pretty sure i still have one chief if you get stuck
when its running like poos, is it misfiring? or has it just got no go.
Postby doin donuts » Fri Jul 22, 2011 8:42 am
rollaholic wrote:pretty sure i still have one chief if you get stuck
Yeah?might get ahold of you if plugs don't work. From idle to about 3k it back fires a little but just has no go,if I'm stopped I have to drop the clutch at round 3k,don't get me wrong,in the rain and in a rwd it's bloody fun but annoying as I start work at 4am and have a 1 month old baby boy so don't wanna wake him up
doin donuts
Postby doin donuts » Fri Jul 22, 2011 6:37 pm
Ok so plugs did nothing,it's getting worse and starting to back fire....HELP
doin donuts
Postby RedMist » Sun Jul 24, 2011 10:24 am
Sounds like it's getting no TPS input. Computer thinks it's got no throttle so adds no fuel. Misfire is a lean misfire. I'd be very wary of running it as is. You'll be running extremely lean mixtures.
I'd check TPS wiring, TPS and computer.
Does the smallport also run MAP? I'm getting so rusty on my 4age stuff.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby doin donuts » Sun Jul 24, 2011 11:06 am
RedMist wrote:Sounds like it's getting no TPS input. Computer thinks it's got no throttle so adds no fuel. Misfire is a lean misfire. I'd be very wary of running it as is. You'll be running extremely lean mixtures.
Ok so running with that would changing the ecu fix it? Iv also been told could be leads?
doin donuts
Postby RedMist » Mon Jul 25, 2011 8:14 am
It could also be leads, coil, injectors, fuel filter, fuel pump, air filter, AFM, vacume leaks
RedMist
Postby doin donuts » Mon Jul 25, 2011 8:39 am
Ok sweet thanks,doing leads today and ecu so will see what happens
doin donuts
Postby doin donuts » Tue Jul 26, 2011 5:55 pm
Well thanks to rollaholic I'm good to go,was ecu,well at least I hope it was,changing it seemed to fix it? Here's hoping!!
doin donuts
Postby doin donuts » Sun Mar 25, 2012 10:18 pm
Ok so problem has surfaced itself again last night!! Drives like a pig below 3k but sweet after that and at idle it's struggling and surging.
Anyone have a diagnostic reader I can throw on it?
Cheers all
doin donuts
