Malcolm wrote:I didn't know they had maths on waiheke
88.4ageGT wrote:can some explain how you get them buy? or make? and why you would use them?
Akane wrote:Just don't do it.
KwS wrote:most rear hinged bonnets have hooks built into the hinge, so in the event of an accident the bonnet gets caught on them and doesnt act like a giant guillotine to the people inside the car.
Raise the bonnet up, those hooks no longer work.
Stupid idea.
KwS wrote:
Stupid idea.
Akane wrote:yea but it doesn't give that racer look.
jondee86 wrote:AE85/86 has a rubber seal between the bonnet and the bodywork
across the back. If you want a gap there, you can just pull the
rubber sealing strip out of its groove. Easy peasy
Cheers... jondee86
metal_sean_head wrote:Akane wrote:yea but it doesn't give that racer look.
But you don't look like a "racer". You look like a 'wanker' or 'poser'
rollaholic wrote:jondee86 wrote:AE85/86 has a rubber seal between the bonnet and the bodywork
Cheers... jondee86
thats a great way to let water run down the back of your engine, corroding the CTS connections etc and causing your car to stop running randomly in the rain / not start after a good rain
