best cv boots?
best cv boots?
Postby themaleman » Thu Aug 25, 2011 8:05 pm
Im after opinions on what cv boots to buy. last time i got some from bnt but after a week they had split again.
the cars quite low so im guessing that might have something to do with them splitting.
i remember hearing the toyota ones are pretty good, can some one confirm this please.
i need both inner and outer
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Mr Revhead » Thu Aug 25, 2011 9:06 pm
Yeah Toyota ones are good.
What brand were the BNT ones? They used to be good.
Postby deaf_rattle » Thu Aug 25, 2011 9:07 pm
id just get genuine ones if they arent too expensive. that way you know they will fit properly.
Postby sergei » Thu Aug 25, 2011 11:04 pm
Genuine are the best ones ;).
As for the brands the Silverline or whatever repco sells comes in "pre cracked" condition.
Postby Mr Revhead » Thu Aug 25, 2011 11:20 pm
sergei wrote:Genuine are the best ones ;).
Postby themaleman » Fri Aug 26, 2011 1:27 pm
not sure what brand they were. revhead do you still do take orders for toyspeeders? if so what do i need to do??
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Bling » Fri Aug 26, 2011 1:30 pm
Postby Bazda » Fri Aug 26, 2011 2:34 pm
To help them survive I have a little trick that helps.
Well def helps esp if your racing the car and it wont cost you anything!
Postby themaleman » Fri Aug 26, 2011 2:35 pm
what is this trick you speak off? will be buying some genuine toyota ones nxt week :D
4agte ae92 Levin
a15 powered sj410
themaleman
Postby AE82 FXGT » Sun Aug 28, 2011 8:42 pm
themaleman wrote:what is this trick you speak off?
+1
AE82 FXGT
Postby themaleman » Wed Sep 14, 2011 7:16 pm
dose anyone know this trick? im waiting for an answer before i replace them!
4agte ae92 Levin
a15 powered sj410
themaleman
Postby 1I1 » Wed Sep 14, 2011 7:30 pm
If it's the trick I'm thinking I saw Barry post ages ago, he puts a split pin between the cv boot and the axle to allow them to vent. Not sure if he's fine tuned what exactly he does?
Ah here we go:
viewtopic.php?t=72545&highlight=split+pin
Bazda wrote:
postfach wrote:Heat + centrifugal force on grease at high speed = busted boots?
Yes thats what I think it is. I actually install a split pin under neath the boot before I clamp it on. To re leave some pressure on the inside. Def helps alot.
TRD Clicky >>Here
1I1
Postby CelicaGT8 » Thu Sep 15, 2011 5:57 pm
Auto stop ones arnt to bad
Repco ones are shet
CelicaGT8
Postby themaleman » Thu Sep 15, 2011 8:14 pm
i got genuine trademe ones this time. im yet to put these ones on (waiting for bazdas reply :))
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Bazda » Fri Sep 16, 2011 11:28 am
hey,
I put a 3mm thick split pin under where the cv boot seals onto the shaft.
Zip tied that down where it sticks out, then put the cv clamp over the boot which also holds the split pin in place.
This allows the cv to breathe better! and no grease comes out there at all.
Postby Weegee » Fri Sep 16, 2011 11:39 am
could try these guys?
http://www.adl.co.nz/Catalogue/
'96 AE111 Trueno BZG (sold)
'01 ZZE123 Runx Z
Weegee
Postby touge_ae101 » Fri Sep 16, 2011 12:23 pm
Bazda wrote:hey,
thanks for that tip i'm going to try it now! i'm forever having CV grease coming out everywhere with both my car and dads ae82 it gets pretty annoying having all the suspension/wheels covered in grease :roll:
touge_ae101
Postby themaleman » Fri Sep 16, 2011 5:45 pm
cheers for that! that will be very help full tomorow!
4agte ae92 Levin
a15 powered sj410
themaleman
