sergei wrote:Genuine are the best ones.
As for the brands the Silverline or whatever repco sells comes in "pre cracked" condition.
themaleman wrote:what is this trick you speak off?
Bazda wrote:postfach wrote:Heat + centrifugal force on grease at high speed = busted boots?
Yes thats what I think it is. I actually install a split pin under neath the boot before I clamp it on. To re leave some pressure on the inside. Def helps alot.
Bazda wrote:hey,
I put a 3mm thick split pin under where the cv boot seals onto the shaft.
Zip tied that down where it sticks out, then put the cv clamp over the boot which also holds the split pin in place.
This allows the cv to breathe better! and no grease comes out there at all.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
