3SGTE TRD Headgaskets
Postby CelicaGT8 » Mon Sep 26, 2011 10:41 pm
Have a TRD gasket in my corona, been in there for abut 3000km and its blowen, did get hot twice like 110deg but other than that iv been nice to it
Ran no more than 16psi boost and usually 10psi
How much shit can these gaskets take? whats the better choice?
In the market for another...
CelicaGT8
Postby Dell'Orto » Mon Sep 26, 2011 10:42 pm
Detonation will still break them. Block and head machined up nicely before installation?
Postby CelicaGT8 » Mon Sep 26, 2011 10:44 pm
Started to ping once apon a time, got it sorted asap with new pump.
Had head checked and both head and block skim'd
CelicaGT8
Postby Grrrrrrr! » Mon Sep 26, 2011 11:00 pm
Dunno about the quality, but nzgaskets does a MLS gasket for 3sgte. STA lists it for $70 incl GST. S2099SSJ
Grrrrrrr!
Re: 3SGTE TRD Headgaskets
Postby allencr » Tue Sep 27, 2011 5:53 am
CelicaGT8 wrote:How much shit can these gaskets take?
Just as much shit as any other if not more.
Re-torqued after a few or many heat cycles?
Head & deck smooth?
Bolt lube?
Threads clean, washers flat & smooth, bolt heads smooth?
Tightened down 10-30% more then factory spec?
allencr
Postby CelicaGT8 » Tue Sep 27, 2011 11:01 am
Head & deck smooth?
Bolt lube?
I would expect a TRD gasket to take more.
Cant really retorque as you do it to a setting then 90deg more of a turn...
Toyota told me to do it to it to the same torque settings as standard
Everything perfectly smooth and clean
Suplied lube on new bolts
CelicaGT8
Paid around $220 for the gasket
CelicaGT8
Postby RunningRich » Tue Sep 27, 2011 6:28 pm
If you are concerned about the headgasket blowing fit ARp headstuds. With the exchange rate at present can't be much more than $200.
It is not recommended to overtorque any 3S headbolts unless you like pulling the corner off the block... :lol:
Richard
http://gtfour.supras.org.nz
RunningRich
Postby CelicaGT8 » Tue Sep 27, 2011 6:39 pm
Studs would be an advantage? Thaught they were mainly for stopping the threads in the block from wearing out. etc
Maby i should sell the bloody thing
CelicaGT8
Postby CelicaGT8 » Wed Sep 28, 2011 2:32 pm
http://www.aclperformance.com.au/Toyota ... askets.htm
ACL Steel gaskets any good? Has anyone used them?
CelicaGT8
Postby strx7 » Wed Sep 28, 2011 5:01 pm
i used ARP studs and a factory ST205 gasket on my build, no issues.
ARP's are the key i think in a performance build
Postby molex » Wed Sep 28, 2011 5:45 pm
Gasket seems to be much less critical than the clamping force. Plenty of people run standard gaskets with big power for long periods of time using uprated head bolts/studs.
Almost certainly going to be poo bolts at fault. Are 3SGTE bolts torque to yield?
molex
Postby CelicaGT8 » Wed Sep 28, 2011 9:10 pm
Studs it seems is the way then. But $240!
ACL steel gaskets are crazy, cheapest i could get one was $270+
Thinking of getting a Cometic head gasket
http://www.trademe.co.nz/a.aspx?id=409961604
CelicaGT8
Postby Grrrrrrr! » Wed Sep 28, 2011 9:29 pm
CelicaGT8 wrote:Studs it seems is the way then. But $240!
Try STA out by airport, they do cometic and list 1.5 and 2mm thickness and will prob be cheaper.
Or $270 will get you full gen3 3sgte TGP gaskets, including MLS head gasket.
Grrrrrrr!
Postby matt dunn » Wed Sep 28, 2011 9:34 pm
What have you been using?
Have you been re-using the old headstuds?
How many times have they been used?
Postby CelicaGT8 » Wed Sep 28, 2011 9:37 pm
Used new head bolts, cant rember the brand but was decent from memory
Gen 3 gaskets are different... but can be used?
Recomend a 1.5 or 2.0mm head gasket?
CelicaGT8
Postby Grrrrrrr! » Wed Sep 28, 2011 9:53 pm
Gne 3 head gasket is fine to use on gen 2 block, and lots of other seal and gaskets are the same, but several are different (rocker cover, oil pump and rear main seal) so you'd need to buy those seperately.
Turbo gaskets are expensive to buy seperately (>$200 for TGP turbo gasket set for gen 2) so a full toyota set is good price.
Grrrrrrr!
Postby Mr Ree » Thu Sep 29, 2011 9:14 am
molex wrote:Gasket seems to be much less critical than the clamping force. Plenty of people run standard gaskets with big power for long periods of time using uprated head bolts/studs.
Yes they are, as that is where the extra 90deg comes into play. You set it to the manufacturers torque spec, then crank 90 degrees (and another 90 in my case)
To the OP...If sticking with bolts, I wouldnt be using no name brand, just get toyota oem TTY, or splash out on the ARP studs
wak thud gush!
Mr Ree
Postby MAGN1T » Thu Sep 29, 2011 2:50 pm
Has anyone read the service manual?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby XS1V » Sat Oct 01, 2011 8:23 am
The TRD head gasket is the same as was used by TTE for the WRC celicas so they can handle just a bit of power :)
Brad
ST205 Group A Rallye #2363
XS1V
