CelicaGT8 wrote:How much shit can these gaskets take?
allencr wrote:CelicaGT8 wrote:How much shit can these gaskets take?
Just as much shit as any other if not more.
Re-torqued after a few or many heat cycles?
Head & deck smooth?
Bolt lube?
Threads clean, washers flat & smooth, bolt heads smooth?
Tightened down 10-30% more then factory spec?
CelicaGT8 wrote:Studs it seems is the way then. But $240!
ACL steel gaskets are crazy, cheapest i could get one was $270+
Thinking of getting a Cometic head gasket
http://www.trademe.co.nz/a.aspx?id=409961604
molex wrote:Gasket seems to be much less critical than the clamping force. Plenty of people run standard gaskets with big power for long periods of time using uprated head bolts/studs.
Almost certainly going to be poo bolts at fault. Are 3SGTE bolts torque to yield?
