Bluetop Rod Bolts
Bluetop Rod Bolts
Postby kiwi4agze » Fri Oct 07, 2011 11:09 am
I am going to be rebuilding a Bluetop 4age to go into one of my employee's AE-82 FX-GT. I have been told to use small block chevy bolts as they can withstand a lot of abuse.. what ones should I order???
Stock ones or Aftermarket ones?
kiwi4agze
Postby Dell'Orto » Fri Oct 07, 2011 11:19 am
ARP probably do a rod bolt for them. Probably overkill unless its gonna be pulling 9000rpm all day or running a lot of boost
Postby kiwi4agze » Fri Oct 07, 2011 11:20 am
The last engine failed due to rod bolt failure... i suspect.
ARP are around $260
Small block chevy $26+shipping from us for 4
He is on a very tight budget..
kiwi4agze
Postby kiwi4agze » Fri Oct 07, 2011 12:20 pm
Dont worry they dont fit.. different size...
kiwi4agze
Postby Bazda » Fri Oct 07, 2011 3:51 pm
I duno who quoted you that ARP 4age rod bolts are $260. lol
They retail around $100-150.
Postby kiwi4agze » Fri Oct 07, 2011 3:55 pm
100-150? Do you know where I can buy them from????
That was from Advanced engine design in auckland
kiwi4agze
Postby QikStarlie » Fri Oct 07, 2011 5:15 pm
QikStarlie
Postby rollaholic » Fri Oct 07, 2011 6:11 pm
i've got some brand new genuines if you are interested, cheaper than ARP.
PM me if you want them
Postby matt dunn » Fri Oct 07, 2011 7:48 pm
every 4age or gze that I have ever seen personally that has thrown a rod had been apart and the old rod bolts re-used.
I have bought about 2 or 3 engines now with thrown rods and found the undone rod bolt nuts in the sump.
They are one part that I personally would never re-use.
I have used new genuine toyota ones in a race engine I built a few years back and never had a problem, but not sure on the TGP price now.
If it is anything like the 20V headstud prices they have probably skyrocketed and are now bugger all cheaper than ARP.
Postby AE82 FXGT » Fri Oct 07, 2011 8:24 pm
For piece of mind considering the price, should get ARP.
If he's on a very tight budget why is he building a motor?
No point doing it half arsed on the cheap and have it shit itself a while later.
AE82 FXGT
Postby kiwi4agze » Fri Oct 07, 2011 9:19 pm
Cause he blew his old motor and needs a replacement
kiwi4agze
Postby AE82 FXGT » Sat Oct 08, 2011 1:04 am
kiwi4agze wrote:Cause he blew his old motor and needs a replacement
Fair enough but the point still stands, you don't want to have play around with things like this if you want a reliable motor.
AE82 FXGT
Postby allencr » Sat Oct 08, 2011 8:33 am
matt dunn wrote:... thrown rods and found the undone rod bolt nuts in the sump.
Undone or broken? Sheared off slightly undone, after pounding from a cooked/seized journal? Sounds like undone is an assembly problem not a bolt strength/quality/shoulda replaced with new one problem.
Thanks.
allencr
Postby MAGN1T » Sat Oct 08, 2011 9:33 am
It's just a case of reading the service manual, as always.
If the job's done properly, it won't fall apart.
Been told?
By somebody?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby d1 mule » Sat Oct 08, 2011 1:35 pm
if he is a super tight budget, buy a second hand motor of TM for like $300, then start this thread again in 2 months when it craps out.
pay peanuts, get monkeys...
d1 mule
Postby AE82 FXGT » Sat Oct 08, 2011 4:29 pm
d1 mule wrote:if he is a super tight budget, buy a second hand motor of TM for like $300, then start this thread again in 2 months when it craps out.
yep, it's one of those things, if you're on a budget, you can't afford not to do it correctly.
AE82 FXGT
Re: Bluetop Rod Bolts
Postby allencr » Sat Oct 08, 2011 6:30 pm
kiwi4agze wrote:I have been told to use small block chevy bolts...
Mind writing what other complete BS you've heard from that source?
Thanks in advance for the laffs!
allencr
Postby QikStarlie » Sat Oct 08, 2011 7:57 pm
Dell'Orto wrote:ARP probably do a rod bolt for them. Probably overkill unless its gonna be pulling 9000rpm all day or running a lot of boost
pretty sure this thread should have ended at the first reply ^
QikStarlie
Postby kiwi4agze » Sat Oct 08, 2011 8:52 pm
I got it from http://www.billzilla.org/4agmods.htm i thought he was well respected?
I asked a question, a simple no would have been more then sufficient allencr
kiwi4agze
Postby Dell'Orto » Sat Oct 08, 2011 10:16 pm
Some of the stuff there is a bit odd...ie adding a chip
