kiwi4agze wrote:Cause he blew his old motor and needs a replacement
matt dunn wrote:... thrown rods and found the undone rod bolt nuts in the sump.
d1 mule wrote:if he is a super tight budget, buy a second hand motor of TM for like $300, then start this thread again in 2 months when it craps out.
pay peanuts, get monkeys...
kiwi4agze wrote:I have been told to use small block chevy bolts...
Dell'Orto wrote:ARP probably do a rod bolt for them. Probably overkill unless its gonna be pulling 9000rpm all day or running a lot of boost
allencr wrote:kiwi4agze wrote:I have been told to use small block chevy bolts...
Mind writing what other complete BS you've heard from that source?
Thanks in advance for the laffs!
