2E running rough
2E running rough
Postby nibblesbro » Tue Nov 01, 2011 4:11 pm
hi, I've got a '89 5 door starlet with the 2E-LEU motor in it, and its running rough as, stalls when i try to accelerate and when it does go it feels like its missing.
Have changed the head and cambelt, help?
nibblesbro
Postby B_giB » Tue Nov 01, 2011 4:35 pm
Cam timing out
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Leon » Tue Nov 01, 2011 5:31 pm
the 2E is also legendary for carb playing silly buggars
Postby Lloyd » Tue Nov 01, 2011 6:25 pm
The carb on a 2E-LEU?
Postby siren676 » Tue Nov 01, 2011 6:26 pm
EFI arent they?
siren676
Postby 1I1 » Tue Nov 01, 2011 7:11 pm
Yup
TRD Clicky >>Here
1I1
Postby Leon » Tue Nov 01, 2011 8:28 pm
Lloyd wrote:The carb on a 2E-LEU?
ah oops, my bad sorry, just assumed 2E
Postby Stu- » Wed Nov 02, 2011 7:22 pm
Could be lots of things but check the rotor/dizzy cap, and that the ballast resistors are plugged in properly, map sensor is connected up etc.
Project Thread
Stu-
Postby Rob » Sun Nov 13, 2011 10:16 am
Its a downdraft carb on it not a side draft which is the one that normally causes all the troubles.
I did the cambelt on this car a few weeks ago when the head was replaced and it was running ok then. Didn't do the timing or check the carb adjustment so could be that.
Also as above with dizzy cap and rotor nibs
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby DVSMOTORSPORT » Sun Nov 13, 2011 1:03 pm
Plugs, leads, timing, airfilter etc, basics first. Then check the dizzy, make sure the mechanical and vacuum advance both operate (done a few with seized mechanical advance counterweights and shaft)
When the head was replaced was the head and block straight? was the head cracked? Just because its just been done doesnt mean it doesnt need to be looked at, same as the cambelt (things happen, even pro's make mistakes), Ive spent a lot of time on jobs thinking "nah thats just been replaced", only to find out someone more senior to me has stuffed it up.
Another thing to check, if its the downdraft carb, shine a torch down the carb (motor not running) and watch while the accelerator is pushed to the floor to make sure the accelerator pump is operating, if its not working it will be very hesitant when taking off and if you snap the throttle it may die as well.
Hi Im Ben, Have a nice day :)
DVSMOTORSPORT
Postby nibblesbro » Thu Dec 15, 2011 4:55 pm
sorry is a 2E-LU, downdraft carb with all the vacuum hoses attached, as rob said he did cambelt and we replaced the head - had it checked for cracks and warpage - head is all good, just finding after its running for a bit it starts stuttering like its not getting enough fuel, cant find the fuel mixture screw on the carb to adjust
nibblesbro
Postby nibblesbro » Thu Dec 15, 2011 5:44 pm
also anyone have any diagrams or service manuals on the '89 EP71 Starlet?
nibblesbro
Postby crispy'86 » Thu Dec 15, 2011 6:33 pm
Wouldn't be something silly like a vacuum hose connected in the wrong place on the carb or manifold or not conected at all. Sounds almost like it's got a big vacuum leak?? Had this same trouble at work when i quickly did a tune on one and forgot to plug one back in.
Failing that fuel blockage for your stalling trouble?? Could pay to pull the carb off and see if you can either clean it and maybe try get a rebuild kit for it. Also had to do this with friends suzuki 4wd that ran real rough and chugged away when it was hot, fresh gaskets and diaphrams and all good
crispy'86
Postby RedMist » Thu Dec 15, 2011 10:23 pm
99 cent tuneup?
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Crucible » Thu Dec 15, 2011 10:52 pm
Have you checked valve clearances? how much vacuum is it pulling at idle? compressions good?
Crucible
Real Life Mechanic
Postby Babz » Mon Dec 19, 2011 4:15 pm
Check the Vacuum Advance. How is it on WOT? If its still missing id be looking at the Carb float. If its not idling make sure there is power going to the idle valve and check to make sure your vacuum advance is fine. Like Stu said could be a lot of things.
1982 Carina TA63 (in the making)
1986 Corona TT141 SR20DE (Rear Ended and For Sale)
1998 Audi A3 1.8T (wifes daily driver)
2011 Mitsubishi Triton (Work Ute)
Babz
Postby DVSMOTORSPORT » Mon Dec 19, 2011 5:16 pm
WTF is WOT????
DVSMOTORSPORT
Postby Bling » Mon Dec 19, 2011 5:22 pm
Wide open throttle.
pretty sure
Postby DVSMOTORSPORT » Mon Dec 19, 2011 5:24 pm
Ahhhhh ok, that makes sense haha, been a mechanic for nearly 15 years and never heard of WOT haha
DVSMOTORSPORT
Postby Babz » Mon Dec 19, 2011 6:31 pm
WTF is WOT????
LOL. Yeap Wide open throttle.
Where about are you nibblesbro? I can have a quick look for you if you are in East Auckland.
Babz
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 13 guests
