kim0663 wrote:Do not use por15 on the outer part of the roof. If you do get some on it, wipe it straight off with thinners, otherwise let dry and grind it all off the outer layer. THat shit cannot be sanded down smooth if you're after a smooth finish later down the track.
I had to grind my por15 off, as I will soon be doing to David's blue beast as well where necessary
sergei wrote:kim0663 wrote:Do not use por15 on the outer part of the roof. If you do get some on it, wipe it straight off with thinners, otherwise let dry and grind it all off the outer layer. THat shit cannot be sanded down smooth if you're after a smooth finish later down the track.
por15 is difficult to deal with and also is water soluble after a time. It must be coated with primer/paint.
Also it only needs paint in uv if you dont want it to fade, the por15 people reckon its only the coloration that is effected by uv, the actual paint is fine.Mr Revhead wrote:Not any of the POR 15 I've used. Only needs paint if in UV light. Otherwise doesn't need paint. It is not porous
