strx7 wrote:sounds like your air flow meter died........
Grrrrrrr! wrote:Double check the connector on the AFM is on properly, and double check for any leaks in the intake piping. The AFM is the primary input for fuel metering at low throttle/revs and it also controls the fuel pump so if that has come loose/failed somehow it'll run like s*it at low revs and stop often. Another thing that may be worth trying is jumpering the fuel pump to run continuously.
I'm not 100% sure, but i think you need to jumper B+ to FP in the diagnostics connector. Somebody on here will correct me if i'm wrong no doubt.
OR you could borrow a known good AFM and swap that in to see if anything changes.
Malcolm wrote::evil: you're ruining the carpet
Users browsing this forum: Majestic-12 [Bot] and 6 guests
