3sgte - Blown headgasket
Postby headshotnz » Sun Mar 25, 2012 10:08 pm
So my mr2 died the other night.
I pulled over, tried to start it, it would start for 2 seconds, wouldn't rev, then cut out straight away.
it was 4 in the morning so i left it were it was and walked home because it was too late at night..
Got back in the morning, looked in the engine bay as i thought that more than likely a hose had popped off or some thing silly like that.
I couldn't see any thing.. and it still wouldn't start, funnily enough :roll:
I look under the oil cap, and what do you know, milky white shit for Africa..
Considering its a fully rebuilt engine I'm not particularly happy..
What is everyone's thoughts on why the gasket blew?
Also i assume that's generally the only reason why milky stuff comes under the oilcap?
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby Malcolm » Sun Mar 25, 2012 10:12 pm
Don't be so hasty! Water is a normal byproduct of combustion, it can leak through the rings and when combined with oil vapour can cause a milky residue to form in the oil cap, the only sure sign of a blown headgasket is chocolate milk in the coolant. Also it wouldn't usually cause an engine to not start/stop running - that's more likely to be something catastrophic or an electrical gremlin. Does it sound like it has compression when cranking? Have you checked error codes?
Postby headshotnz » Sun Mar 25, 2012 10:19 pm
Hmm abit of positive insight thanks Malcolm,
No I'm towing it home tomorrow its currently parked 15 minutes away from home at the moment.
Catastrophic?
I'm assuming if it didn't have compression it would sound notably different before it died?
Ill be sure to check for codes as soon as i get it home tomorrow
headshotnz
Postby levinguy » Sun Mar 25, 2012 10:24 pm
does it crank over at normal speed? if so does it spark? like Malcolm said, don't just assume its the headgasket, wouldn't think it would just happen like that
levinguy
Postby wde_bdy » Sun Mar 25, 2012 10:26 pm
Condensation collects in the highest point of the engine, my 4K-E for example (with the very tall filler neck due to the EFI setup) will collect a lot of moisture/milky shit doing lots of short trips. Give it a decent run and get it heated up on a decent trip and absolutely no issues.
Callum
wde_bdy
Postby strx7 » Sun Mar 25, 2012 10:27 pm
sounds like your air flow meter died........
Postby headshotnz » Sun Mar 25, 2012 10:31 pm
Yeah it sparks. Well the engine starts for literally two seconds then dies.
Before the other night there was only one issue with the engine. It was horrible to drive between 2k and 3k RPM, It had new leads and now rotor, and new plugs (i put other new plugs in that was in a spare engine that i had that i knew worked) and was still doing it.
So i had the intention of seeing if the TPS was faulty(dead spot in the range?) or if the TPS was wrongly aligned.
Say for instance the TPS did die, would the engine dying be a symptom of the TPS?
Maybe its not allowing fuel into the engine hence why it wont idle?
headshotnz
Postby headshotnz » Sun Mar 25, 2012 10:33 pm
strx7 wrote:sounds like your air flow meter died........
To be fair, yes i did think this at first, well i thought maybe it had come unplugged.
I have a spare i can try tomorrow, Cheers for that mate :)
headshotnz
Postby Grrrrrrr! » Sun Mar 25, 2012 10:44 pm
Double check the connector on the AFM is on properly, and double check for any leaks in the intake piping. The AFM is the primary input for fuel metering at low throttle/revs and it also controls the fuel pump so if that has come loose/failed somehow it'll run like s*it at low revs and stop often. Another thing that may be worth trying is jumpering the fuel pump to run continuously.
I'm not 100% sure, but i think you need to jumper B+ to FP in the diagnostics connector. Somebody on here will correct me if i'm wrong no doubt.
OR you could borrow a known good AFM and swap that in to see if anything changes.
Grrrrrrr!
Postby headshotnz » Sun Mar 25, 2012 11:23 pm
Grrrrrrr! wrote:Double check the connector on the AFM is on properly, and double check for any leaks in the intake piping. The AFM is the primary input for fuel metering at low throttle/revs and it also controls the fuel pump so if that has come loose/failed somehow it'll run like s*it at low revs and stop often. Another thing that may be worth trying is jumpering the fuel pump to run continuously.
Cheers mate, B+ to FP sounds about right, ill double check online any way.
I have a spare AFM from my other mr2 and ill check again for vacuum leaks.
Thanks again for all the help every one, ill post up my findings tomorrow
headshotnz
Postby Dell'Orto » Sun Mar 25, 2012 11:36 pm
TBH I wouldnt be surprised if the AFM did cark it, it had been sitting in the boot for a while before I got it, and was fairly coated in oxidisation.
Postby Malcolm » Mon Mar 26, 2012 10:10 am
Actually the air leak thing is also pretty likely - it's very common to get splits in the hose in the rubber inlet hose before the compressor, and in the rubber connectors in the intercooler piping, have a good visual check over of them.
Postby Dell'Orto » Mon Mar 26, 2012 10:11 am
Intercooler pipe joiners ought to be fine, most of them are new silicon ones. Worth checking the AFM to turbo pipe though. Sounds exactly like what it did to me when it blew the bottom intercooler pipe off too
Postby headshotnz » Mon Mar 26, 2012 10:52 am
hahahahaha. I bet you two too it
Thats the bit that comes off the compressor.
$&#$%, do i feel like a right knob end. :oops:
Some thing just doesnt look right...
Lucky i have a spare that i can use from my other mr2...
Will go test now to see if its ok.
Thanks for the help none the less Malcom. Brad and every one else.
James
headshotnz
Postby Malcolm » Mon Mar 26, 2012 11:03 am
:evil: you're ruining the carpet
Postby strx7 » Mon Mar 26, 2012 11:11 am
thats what you get from using those style of hose clamps they cut their way thru the pipe.
Postby Dell'Orto » Mon Mar 26, 2012 11:22 am
You'd think Toyota would know better
Postby Lloyd » Mon Mar 26, 2012 11:45 am
Toyota/everyotherjapanesemanufacturer
Postby headshotnz » Mon Mar 26, 2012 11:53 am
Malcolm wrote::evil: you're ruining the carpet
Good, there shouldnt be carpet in the garage, period :twisted:
FIXED!! and holy hell, its now boosting some were between 17 and 19 psi :O
Id say it had an airleak down there the whole time.
This blitz ECU must be tuned for a ct20b, it would destroy ct26's...
headshotnz
Postby Dell'Orto » Mon Mar 26, 2012 12:22 pm
You might wanna try get that under control, or it will end up with a BHG :lol: Must be $&#$% quick!
Users browsing this forum: Bing [Bot] and 12 guests
