3SFE oil filter
3SFE oil filter
Postby redline racer » Wed May 09, 2012 1:44 pm
Hi all, have noticed the oil light on my 3sfe st202 celica is a bit slow to go off on cold start.
It is due for a oil change and was wondering if it would be worthwhile fitting a toyota oil filter.(currently has a ryco) Have been told factory oil filters hold better oil pressure? unsure weather to believe this or not. factory filter is $30 Ryco is $13 so you would hope there would be some difference? car has done 160k so im not expecting a miricle cure but if it helps its worth a shot possibly?
redline racer
Postby Burning Angel » Wed May 09, 2012 4:33 pm
rycos arent bad filters.
The thing that most affects oil flow when cold is what type of oil you have in it(ie. 15w40 10w40 etc)
Also 3s engines have the oil pressure sensor in the head, not the block like most engines(at least 3sg engines do, not sure about 3sf) so the oil light tends to take longer to turn off.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby MAC_HATER » Wed May 09, 2012 5:11 pm
my 3S-GE celica did that - it scared the shite out of me as i knew what 3S-GE's did when oil was starved
i changed from a ryco oil filter to a donaldson and it helped a fiar bit - was 15 seconds till the oil light went away down to about 4-6 seconds with the donaldson oilfilter
my engine was probably half shot anyway - but the donaldson oil filter did help it seems
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Re: 3SFE oil filter
Postby sergei » Wed May 09, 2012 6:16 pm
redline racer wrote:Hi all, have noticed the oil light on my 3sfe st202 celica is a bit slow to go off on cold start.
Factory filter is $22 from Mark (I1I) TS TGP sponsor. It definitely solved cold start up rattle on high km 20v.
Postby Mr Revhead » Wed May 09, 2012 7:05 pm
Some after market drain back valves are a bit..... well shit really.
Was very common on the old ryco 191as, but they are well gone now!
386 should be ok.
Postby redline racer » Thu May 10, 2012 10:06 pm
thanks for all the replies 8)
think i'll give the toyota filter a shot.
Iam using 15w-40. it burns a bit and needs checking every few weeks which i thought is strange, But I used to have a 60km levin bzv and that burnt oil too. have never noticed the celica visually smoking so must be at high rpm only. although it only gets high rpm now and then if passing etc otherwise just normal driving..
redline racer
Postby Mr Ree » Fri May 11, 2012 11:15 am
Why not try going to a thinner grade of oil at the same time as changing your filter?
I dont know what toyota recommend you use for your motor but my 5sfe gets 10w-40 and the oil light is off in a few seconds from stone cold
wak thud gush!
Mr Ree
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
