Is a 4AG(T)E better than a 3SGTE?
Postby iOnic » Sun Jun 10, 2012 1:42 pm
Marketing what? Toyota had stopped making the 3S by the time the JGTC engines were displayed and specs given out. Not that the parts were available for sale when they were in production anyway. They could have called it a 503e like they had with previous 503e's. I'm curious about what marketing logic stopped them from doing that. Also curious about why the head and block castings are identical to 3SGTE items whereas the 503e was entirely different for the 10 years prior.
I know they aren't the same 3S you'll find in nana's Caldina but neither is the 1UZ in the MC8R the same as in nana's Celsior or the atlantic spec 4AGE the same as the one in an AE92.
Postby Mr Revhead » Sun Jun 10, 2012 1:56 pm
There are many versions of the 503e. Also can you find official Toyota naming of the
503e
Postby iOnic » Sun Jun 10, 2012 2:11 pm
I can find official Toyota naming of this engine being a 3SGTE. Can you find any such thing saying it isn't? TRD call it a 3S, It looks like a 3S and I'm inclined to believe them.
You're the one saying it's not a 3S - Prove it.
Postby Jdawg » Sun Jun 10, 2012 2:38 pm
I like the pic of the 3S on the engine lifter. The only tool you ever need lying right there on the floor:)
Jdawg
Postby DeeCee » Sun Jun 10, 2012 2:58 pm
Can we please get back on topic? The race stuff is detracting from the OP's intent.
GT Four Adovansu
DeeCee
Postby sergei » Sun Jun 10, 2012 3:20 pm
Looking at the Supra 3S pics, that is definitely not 503e. The head looks like Gen3 3S, and block looks like Gen4 3S block.
Postby Mr Revhead » Sun Jun 10, 2012 5:26 pm
Was a thread posted here ages ago on the JTCC engines. Might have been about the car that ended up in Ozzie. But im sure it was definitely not a 3s engine. Will search it when at a pc again.
Postby gt4dude » Sun Jun 10, 2012 7:37 pm
i cant point to a single thing that i recognise on that TRD3SGTE.
however, the WRC Corolla looks very obviously a modified ST205 motor, It actually doesn't look quite as complicated as the WRC ST205 Celica's engine bay.
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby QikStarlie » Sun Jun 10, 2012 8:26 pm
what have you done roman.
maybe if takumi fujiwara had a 3sgte in his ae86 the 3s would be more popular
4age works, no drama's, more compact, lighter even if its only a small amount like 14kg someone said, thats alot in a small car. plus 4a being more compact the weight is more rearward in rwd car. so that 14kg compounds for more weight out the front. (without going to the effort of firewall mods of course). 3s has its place. but if i wanted a big power 4cylinder i'd use a 2rz or 3rz
QikStarlie
Postby headshotnz » Sun Jun 10, 2012 8:56 pm
Does any one have any complaints about turning a 2zzge around so its rwd and sticking a churbro on it?
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby levinguy » Sun Jun 10, 2012 11:31 pm
proof?
the pic's say 3sgt?
levinguy
Postby gt4dude » Sun Jun 10, 2012 11:52 pm
actually one thing i do recognise is the angle of #1 exhaust runner compared to the rest of them,
I'm not sure about gen 1 & 2 but i remember vividly the st205 motor, #1 exhaust port is wider due to the flow restrictions on the inside, so when creating the manifold #1 tube is cut on an angle to allow that wider port size
the block looks similar aswell
200AWKW / 370NM
gt4dude
Postby sergei » Mon Jun 11, 2012 12:20 am
iOnic wrote:Image
That is definitely Gen3 (ST205) head.
Here are the signs:
Look at the spacing of bolts on the rocker cover.
The original bolt holes for the alternator braket are there.
The unused threaded hole on the #1 exhaust port.
Identical reinforcements casts (correct terminology?).
Not so sure on the block as it is missing dipstick hole, so I assume it is Altezza one.
Here is a random pic of a ST205 engine:
Postby gt4dude » Mon Jun 11, 2012 12:27 am
the rocker cover looks quite possibly like a ge?? cover with the lump and the filler port shaved off
200AWKW / 370NM
gt4dude
Users browsing this forum: Majestic-12 [Bot] and 20 guests
