Dell'Orto wrote:2ZZ
Kiwi-Corolla wrote:Anyone see October's NZ Performance Car magazine? Some guy overseas has already chucked a 2JZ-GTE in one.
ae82 gt 4 us wrote:So was this to replace the one that they may have crashed on test drive?
Red GT Auto Port Hills.
If you were to repower one of these 86, what would peoples choice be?
3sge Beams engine with 6 spd? or for a laugh go with 4age, bit underpowered option thou.
ae82 gt 4 us wrote:Sorry I'm a loyal Toyota man and was thinking what Toyota set up would be best.
Did you also know that a 3sge Beams also has a bore and stroke of 86mm, which goes nicely with the 86 them.
VR-4Squid wrote:Saw a TRD one at BP in Welly (taranaki st) this morning, brakes looked suitably impressive in person.
ae82 gt 4 us wrote:What is balance?
When a roll cage goes in, interior gets removed, fat driver inserts himself at lowest seating position. I have had a measure up and would say the cylinder head is the only part higher than the flat boxer engine. 20kg weight higher by 200mm is this really going to upset the characteristics that much.
As soon as a roll cage goes in surely that must count for a comprise of weight vs handling.
