Sw20 Gen 2.5 Build (Of sorts)
Postby mcfatty1000 » Sat Mar 16, 2013 8:48 pm
The wires I seem to be missing are the ones called G1, G2 and NE.
They're just not there at all
mcfatty1000
Postby sergei » Sun Mar 17, 2013 11:20 pm
mcfatty1000 wrote:The wires I seem to be missing are the ones called G1, G2 and NE.
These wires should be shielded (as single bundle). So generally you wou be missing a single "wire". Without them your car would not start at all.
Postby mcfatty1000 » Sun Mar 17, 2013 11:28 pm
Thats exactly my point. It shouldn't.
They're not plugged into the ecu, the plug or even to be found at all. And the car has been running for at least two years like this?
I'll get some photos later in the week if possible. One of the other plugs has a distributor signal though, surely this wouldn't be enough to make up for that though? I mean, that is there from factory too
mcfatty1000
Postby sergei » Mon Mar 18, 2013 1:08 am
mcfatty1000 wrote:Thats exactly my point. It shouldn't.
Distributor signal IS G1/G2/NE.
Postby mcfatty1000 » Mon Mar 18, 2013 8:14 am
haha, I know. Which is why I can't understand how its running at all.
I'll have to take some photos as proof. And then never touch the ecu ever again in case I upset it and it never goes again.
On a related note, how do the gen 2 plugs work? They're slightly different to the gen 3 ones so I'm having trouble getting the pins out
mcfatty1000
Postby sergei » Mon Mar 18, 2013 8:26 am
mcfatty1000 wrote:haha, I know. Which is why I can't understand how its running at all.
The G1/G2/NE signal will be coming of the distributor. It will be 4 pin plug. just trace those wires. The shielding stops ~10cm before the ecu.
I have done something slightly different.
I replugged ST165 loom for ST185 ECU (which is same/similar as Gen1/2 SW20). The way I did it is I went to pick-a-part and chopped off random Camry/Corolla plugs and connected the ends. The pins in my case were different so I could not re-use ST165 pins in new plugs.
Postby gt4dude » Mon Mar 18, 2013 9:24 am
Hows that 165 coming along Serg? Wouldn't mind seeing it again in a later stage
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby sergei » Mon Mar 18, 2013 9:31 am
gt4dude wrote:Hows that 165 coming along Serg? Wouldn't mind seeing it again in a later stage
Not going anywhere.
I am at stage where I need to buy a lot of things like seats, coilovers, halfcage, ST205 i/c radiator, i/c pump, injector resistor, get oil cooler sorted (more $$$ fittings), retune and cert.
Having STI does not help as it is a very nice car to drive ;).
Postby mcfatty1000 » Mon Mar 18, 2013 9:43 am
Yeah, seems I may be missing that plug may be absent entirely.
Ok, I'll have a look down there next weekend or so - thinking I've upset the injector 1 wire by trying to get the pin out of the plug which is the leading suspicion why the car is missing on one.
mcfatty1000
Postby mcfatty1000 » Thu Apr 04, 2013 1:10 am
Right, have the car up and running properly again, still on the gen 2 ecu though.
Still wanting to go to a new ecu to get the most out of the engine, so thinking I've got two options, a adapter loom from the gen 2 wiring to the gen 3, or to go fully aftermarket.
Anyone know if one can get the 26, 16 and 22 pin plug sockets? I have the four plugs that would go on the gen 3 ecu end.
Or, what aftermarket options do I have? Bear in mind its a na engine, but I plan on keeping it pretty much forever. Older G series link? Plug and play?
mcfatty1000
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
