Bootlid not popping
Postby Dell'Orto » Wed May 22, 2013 8:34 pm
Might need to pop the boot lock if its the type that protrudes from the boot lid and manually operate the lock
Postby JZCrazy » Wed May 22, 2013 8:52 pm
Has your JX90 got a valet lock for the Boot?
Soarer NooBs fall for this one all the time.
JZCrazy
Postby Stott69 » Wed May 22, 2013 9:10 pm
vr4boy wrote:Cut a hole in the boot?
Lol was thinking this
Stott69
Postby drift-monkey » Wed May 22, 2013 9:14 pm
if you're providing a new boot, sure! 8)
drift-monkey
Postby drift-monkey » Wed May 22, 2013 9:22 pm
Just went outside and fiddled with it, put the key in, turned it all the way to the left, pulled lever, nothing. turned it straight, pulled lever, nothing. turned key all the way to right, again, nothing.
Did this jsut to make sure I wasn't missing anything super obvious.. Is there some super secret lever that I wasn't told about?
Oh, and this is also with the secondary key. One for ignition and boot. The main one is with my brother at the moment.
drift-monkey
Postby MR2SIK » Wed May 22, 2013 10:13 pm
drift-monkey wrote:Just went outside and fiddled with it, put the key in, turned it all the way to the left, pulled lever, nothing. turned it straight, pulled lever, nothing. turned key all the way to right, again, nothing.
Sure it's not a 'valet' key, door lock and ignition? So unable to access glovebox and boot?
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby drift-monkey » Wed May 22, 2013 10:17 pm
nope, can get in and out of glovebox with it, turn car on, lock doors etc etc.. boot is another story.
drift-monkey
Postby phoenix » Wed May 22, 2013 10:35 pm
Any rubber bungs in the underside of the boot that you could remove and get a pipe through to try and shift the wheels?
phoenix
Postby drift-monkey » Wed May 22, 2013 10:48 pm
phoenix wrote:Any rubber bungs in the underside of the boot that you could remove and get a pipe through to try and shift the wheels?
Good idea. Hopefully the cardboard and carpet and sxxt doesn't get in the way.. Will try it tomorrow and post results.
drift-monkey
Postby drift-monkey » Fri May 24, 2013 12:42 pm
Flew over a speedbump, nothing. Jacked it up super high, nothing. Tried moving wheels with a metal rod through the bottom of boot, nothing. Tried both keys, only one fits properly.. I don't know anymore.
When the time comes, I might just buy a new boot, and tear this one up. ha.
drift-monkey
Postby Boost_4_Life » Fri May 24, 2013 1:02 pm
take it to a dodgy neighbourhood and put word out that there are some mint wheels inside? sure someone will be able to practise their skills...
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby jspec153 » Fri May 24, 2013 6:55 pm
not too sure about your car but nissans have a small locking tab just below the catch on the car in the boot but you would have to some how get into the back, a cefiro i had done that they have a tiny little port hole in the back seats used a umbrella to unlock it dumb ass idea other than that go see the local fire brigade and get them to use their jaws to pop it haha fun times...
good luck!
jspec153
Postby fielderz » Sat May 25, 2013 11:51 am
Could try calling a locksmith out after explaing the issue over the phone, some have some very sneaky tricks. Could be cheaper and less hassle than tearing the boot up.
fielderz
Postby drift-monkey » Sat May 25, 2013 6:46 pm
Currently got the rear seats out and can just see the inside of.the boot over the tank, still pretty stumped on what is wrong.. moved the wheels around and they don't seem to be getting.caught on anything..
Could it be an electrical fuse, a hidden lock, a ... something... because everything mechanical looks fine. The lever pulls fine, it pulls the cable, and you can hear it pulling the boot latch, but the boot just won't come up.
drift-monkey
Postby drift-monkey » Sat May 25, 2013 7:21 pm
fielderz wrote:Could try calling a locksmith out after explaing the issue over the phone, some have some very sneaky tricks. Could be cheaper and less hassle than tearing the boot up.
I think that will be second to last resort. I could just be something super obvious.. I don't know.
drift-monkey
Postby KinLoud » Sat May 25, 2013 8:36 pm
Find an identical car and hop in the boot - see how the mechanism works and how to open it from the inside
Postby WCKWGN » Sat May 25, 2013 9:20 pm
have some one push down on the boot applying pressure while you pull the latch ie 2 person job if you feel everything is connected... maybe it is sitting in a compramised position had similar on my camry
WCKWGN
Postby drift-monkey » Sat May 25, 2013 9:31 pm
WCKWGN wrote:have some one push down on the boot applying pressure while you pull the latch ie 2 person job if you feel everything is connected... maybe it is sitting in a compramised position had similar on my camry
yeah, tried this a few times, along with pulling pushing sitting ... left both me and my dad staring at it thinking wtf along with many other people. No one seems to know what it is. Everything is working, but it's not working.
drift-monkey
Postby 85AW20v » Sun May 26, 2013 11:56 am
KinLoud wrote:Find an identical car and hop in the boot - see how the mechanism works and how to open it from the inside
And you only need to use a screwdriver pushing down on the mechanism to lock it see how it all works.
See ya
Simon
85 MR2 20v
85AW20v
Postby drift-monkey » Mon May 27, 2013 1:32 am
Have the local locksmith coming to look at it. fingers crossed. Sorry for this this thread. Bit useless with no real conclusion to it .. a whole two pages already. Ha.
drift-monkey
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
