Post Reply
Mr Ree
Post by Mr Ree »
Stott69 wrote:
Mr Ree wrote:Im going to be running an ECU for the GTE, and the coils/ignitor from a VVTI GTE, and deleting the dissy cap/leads, but retaining the dissy base for the cam and crank angle sensors.
Ill upload some pics to a host site, and then put a couple in here so you can see how much tidier it is with the GTE cam covers, and without the big mess of dissy cap/leads lol
Down the road, if I end up getting a stand alone, then I will use the CAS from the 7MGTE as its even lower profile than the billet cap I have on my dissy base
Why the VVTI coils and ignitor?
Because they are far newer than normal GTE coils, less likely to be cracked/faulty, and they output lightening bolts like a boss :)
And because I got them for a great price too ;)
wak thud gush!
2jayzgte
Post by 2jayzgte »
Front TE 37 SL's ordered yyyeeeehhhaaa c'mon me.
Mr Ree
Post by Mr Ree »
Very nice :)
It will look hot with SL's as your street rims.
Did you end up getting a sharper price for them than we ere discussing a few weeks ago?
wak thud gush!
2jayzgte
Post by 2jayzgte »
Mr Ree wrote:Very nice :)
Yep $1500 to my door.
1I1
Contact:
Post by 1I1 »
Finished getting Corolla ready for road and track tomorrow. Oil changed and 15's fitted up.... was hoping to get a decent timed dry day, guess not. Rain looks to be pretty set in, doubt it'll lift before tomorrow.
TRD Clicky >>Here
l SIC l
Post by l SIC l »
Random question: Does anyone know what club was holding a gymkhana at Ellerslie Racecourse today (Car Fair area)? There was a few Lotus 7s, Lotus Elise, AE86 Trueno lift-back (tidiest you'll ever see in your life), R33, Onevia S13, a few MX-5s (one with an 8 or 9-year-old driving) + more
R35 GT-R 'Black Edition' 750HP
86' AE86 GT Apex
96' S2 RZ Supra
R34 GT-R V-Spec
Contact:
Post by Mr Revhead »
Raised it! Lowering is for girls :twisted:
Before
https://lh5.googleusercontent.com/-zbLK ... 110041.jpg
After
https://lh4.googleusercontent.com/-2JGt ... 162753.jpg
Dipshit me forgot to measure before I did it, but it's around 3" higher at the back now
Mr Ree
Post by Mr Ree »
Now thats more like it.
I might have to get some details from you at a later date ;)
wak thud gush!
steroidcontaskie
Post by steroidcontaskie »
Got the car back together, filled the fluids and started the engine........huge fluid leak from the front of the transmission. Stink!!! Looks like it is all coming out again.
Science never sleeps...
RVR Turbo (idle)
2jayzgte
Post by 2jayzgte »
Pretty happy with that if I'm honest.
Grrrrrrr!
Post by Grrrrrrr! »
Bolted on the modified fuel rail, turned the key and watched a nice fine mist of petrol spray across the head from a pinhole leak in the brazed up fitting. Decided that I wasn't in the mood for playing firefighter and turned it off.
Went car shopping instead and wasted an afternoon asking sales plebs what have you go in manual that has got a bit of go.
Stott69
Post by Stott69 »
Ripped the dump pipe out, pain in the ass! Cut the top flange off, then reinstalled everything with a loose flange. Now need to weld the flange back on now its sitting right. Also started make a pattern for the cold air box.
Mr Ree
Post by Mr Ree »
Stott69 wrote:Ripped the dump pipe out, pain in the ass! Cut the top flange off, then reinstalled everything with a loose flange. Now need to weld the flange back on now its sitting right. Also started make a pattern for the cold air box.
Is this a new problem Scott, or the same fitment issue you discovered when you first installed the new manifold/dump?
On that note, I forgot to ask how you get on when you sent it back to be altered. Did he sort it all out for you with no more added costs etc?
Im going to be buying a new manifold next year so keen to hear what the after sale service has been like.
wak thud gush!
Stott69
Post by Stott69 »
Yea, got done at no extra cost. Think one of the vbands may have been loose when we fabed up the w/g return hence things not sitting 100%. Tryed fixing it with ali gaskets, but they all but disintergrated on my road trip.If I did it again Id buy the manifold off Mike then get some one local to do the dump and w/g.
Next on the fix list is coolant lines and radiator.
blindnz
Post by blindnz »
l SIC l wrote:Random question: Does anyone know what club was holding a gymkhana at Ellerslie Racecourse today (Car Fair area)? There was a few Lotus 7s, Lotus Elise, AE86 Trueno lift-back (tidiest you'll ever see in your life), R33, Onevia S13, a few MX-5s (one with an 8 or 9-year-old driving) + more
Likely to be the sports car club sccnz.co.nz have been down for a watch there before
iOnic wrote:Don't take me too seriously - I own an MR2.
Scottie
Post by Scottie »
Purchased a new one and drove it from the bottom of south island back to Auckland.
When the guy says "freshly repainted wheels" (and you can see the overspray on the dirt inside the rim he didn't bother to clean) its code for the front calipers are leaking brake juice. Which I found out gassing up in Taumuranui.
Hopefully got some good timelaspe stuff
Needs a bit of tidying up. I already have some replacement trim pieces I picked up from Pick a part Christchurch.
Shrike
Post by Shrike »
Scottie wrote:Purchased a new one and drove it from the bottom of south island back to Auckland.
Going off what might be a boost guage inside hoping its a gt4???
Kiwi-Corolla
Post by Kiwi-Corolla »
Shrike wrote:Going off what might be a boost guage inside hoping its a gt4???
If you squint your eyes a little and look really closely you can just make out the 'GT FOUR' badge on the bootlid ;)
Post by Lloyd »
Scottie
Post by Scottie »
Oh yep, a GT4. The owner had to check how much boost it ran after I asked him (It has a cut and bent ST215 heat shield and I was fearing the worst). He (a mechanic) had to check, and replied 3 days later(RED FLAG)saying 12psi, seems legit. After picking it up I noticed the gauge (that read in bar) was only reading .7(~10psi), Fcuk. Got to timaru and stopped for the night - gauge was reading a whole lot of vacuum when engine off, eg stuffed. So its is prob ok, apart from the missing downpipe bolts(no leak) and about a zillion other things.
Post Reply
