Postby Bling » Fri Oct 04, 2013 8:34 pm
How is that coming along? Always wanted one :oops:
Postby hsmidy » Fri Oct 04, 2013 9:19 pm
Slow, as always it comes down to money, plus I've been fairly busy...2 kids, new job, renovating the house....the list goes on.
if the new shifter position is all good, I will be welding up the tunnel soon.
hsmidy
Postby Bling » Fri Oct 04, 2013 9:26 pm
Sounds like you have a fair bit on your plate! Chuck up a photo of the progress sometime. Keen to see it.
Postby Grrrrrrr! » Fri Oct 04, 2013 9:56 pm
Took it for a WOF. Emailed mark. Looked at a couple of fresh imports Euro Rs.. Might own one by the end of next week if compliance & panelbeaters don't drag the chain.
Grrrrrrr!
Postby steroidcontaskie » Sat Oct 05, 2013 5:20 pm
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Postby Mr Ree » Sat Oct 05, 2013 5:28 pm
Removed my throttle cable, intercooler and enough SS piping to build an HVAC plant room, in preparation for the new parts to be fitted next weekend.
wak thud gush!
Mr Ree
Postby Mr Revhead » Sat Oct 05, 2013 5:29 pm
Made a seal between the bonnet and topmount. Para rubber FTW!
And a heat sheild so turbo stops turning intercooler into a BBQ plate :lol:
Note: Read ACL heat shield instructions BEFORE starting.
That way you avoid using the cutting wheel on the grinder before you read the bit about using methods that avoid making toxic dust :?
Postby Mr Ree » Sat Oct 05, 2013 10:04 pm
Aviation snips are the best tool for cutting that ACL stuff up. Just put it between the rows and it cuts like butter :)
wak thud gush!
Mr Ree
Postby Mr Revhead » Sat Oct 05, 2013 10:16 pm
I'll remember those words on my death bed :lol:
Postby Bling » Sat Oct 05, 2013 10:42 pm
Everything is toxic these days. :?
Postby Looonie » Sun Oct 06, 2013 4:49 pm
steroidcontaskie wrote:Image
Jealous of super clear headlights... aftermarket?
Rumple dee pumple dee doo...
Looonie
Postby CAMB01 » Sun Oct 06, 2013 5:55 pm
Gave my daily whip corolla a big birthday.
Cambelt, waterpump, seals, thermostat, coolant, rocker cover gasket, oil and filter.
Good for another 100000km.
Bring on 400000km.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby steroidcontaskie » Sun Oct 06, 2013 7:30 pm
Yup, they are.
Cheap LHD ebay ones that I heated up in the oven, opened up and modified the projection so it has a RHD pattern, however...... the adjustment on them is crap and when you get them to the right level the projector ends up all loose and moves up and down. I then bought some RHD ones (that cost 3 times the price) and they are just as bad.
They look awesome, so I am going to taken them appart again and do a proper HID conversion on them with OEM HID projectors and new adjustments. Will let you know how it goes.
Edward
RVR Turbo (idle)
steroidcontaskie
Postby Leon » Sun Oct 06, 2013 8:42 pm
wax on, wax off, on the Sprinter 110 daily :)
Postby crispy'86 » Sun Oct 06, 2013 9:40 pm
fitted the brackets for the distributor, put the front wheels on, topped up radiator to find I have a leak from the water pump. That'll teach me to do things in a rush. Least I could move it in the driveway.
crispy'86
Postby JZCrazy » Sun Oct 06, 2013 9:55 pm
Got the rear bar fitted up on TT Soarer.
Side skirts will be next. Hmmm
Filled the TRD Diff with oil ready for installation.
JZCrazy
Postby blindnz » Sun Oct 06, 2013 10:38 pm
Did a sweet string wheel alignment 8)
iOnic wrote:Don't take me too seriously - I own an MR2.
blindnz
Postby Mr Ree » Mon Oct 07, 2013 10:08 am
JZCrazy wrote:Got the rear bar fitted up on TT Soarer.
Likes ^ ;)
wak thud gush!
Mr Ree
Postby Grrrrrrr! » Fri Oct 11, 2013 4:40 pm
Acquired a Honduh!
Grrrrrrr!
Postby Bling » Fri Oct 11, 2013 7:06 pm
Looks tidy! 8)
