steroidcontaskie
- Toyspeed Member
Mock fitted my trans-cooler fan and radiator cover.
[img][img]http://i615.photobucket.com/albums/tt233/steroidcontaskie/Noradiaotrcover.jpg[/img][/img]
[img][img]http://i615.photobucket.com/albums/tt233/steroidcontaskie/Radiatorcover.jpg[/img][/img]
Science never sleeps...
RVR Turbo (idle)
RVR Turbo (idle)
- Mr Revhead
- SECURITY!
- Contact:
Made a seal between the bonnet and topmount. Para rubber FTW!
And a heat sheild so turbo stops turning intercooler into a BBQ plate
Note: Read ACL heat shield instructions BEFORE starting.
That way you avoid using the cutting wheel on the grinder before you read the bit about using methods that avoid making toxic dust
- Mr Revhead
- SECURITY!
- Contact:
Gave my daily whip corolla a big birthday.
Cambelt, waterpump, seals, thermostat, coolant, rocker cover gasket, oil and filter.
Good for another 100000km.
Bring on 400000km.
Bring on 400000km.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
steroidcontaskie
- Toyspeed Member
Looonie wrote:steroidcontaskie wrote:
Jealous of super clear headlights... aftermarket?
Yup, they are.
Cheap LHD ebay ones that I heated up in the oven, opened up and modified the projection so it has a RHD pattern, however...... the adjustment on them is crap and when you get them to the right level the projector ends up all loose and moves up and down. I then bought some RHD ones (that cost 3 times the price) and they are just as bad.
They look awesome, so I am going to taken them appart again and do a proper HID conversion on them with OEM HID projectors and new adjustments. Will let you know how it goes.
Edward
RVR Turbo (idle)
RVR Turbo (idle)
fitted the brackets for the distributor, put the front wheels on, topped up radiator to find I have a leak from the water pump. That'll teach me to do things in a rush. Least I could move it in the driveway.
