How to prove car not airbag optioned?
Postby Linesy » Fri Jan 09, 2015 10:11 pm
I've got a Ae101 Trueno that I picked up for loose change, threw a spare engine in and have been using for clubsport while I got my AE92 ready.
The car came with a random steering wheel fitted that came off an airbag car (had deployed) as someone swiped the racing type wheel that was fitted.
Anyway my lad was having troubles with his Commodore so I suggested he run the Trueno down for a WOF to get it on the road to use.
Car is remarkably good & only needed a stone chip fixed in screen and a seatbelt BUT also did not pass due to airbag having deployed.
Now this wheel did not come off this car but hard to tell import Mechanic at VTNZ that.
Is there anyway to tell via vin etc if airbag was not fitted???
Any help would be greatly appreciated to sort this.
Linesy
Linesy
Re: How to prove car not airbag optioned?
Postby 1I1 » Fri Jan 09, 2015 10:36 pm
If you fire through the full frame number and model code to me I should be able to confirm that for you in writing
TRD Clicky >>Here
1I1
Postby matt dunn » Fri Jan 09, 2015 10:39 pm
If it has SRS it would probably be written on the sunvisor.
It would be logical to expect that if you go for a warrant with a air bag steering wheel with no bag in it,
that it would fail,
but if you went with a steering wheel that never had an airbag it would have probably passed,
as apart from the sunvisor how else does the warrant guy know if it has one or not?
Postby Linesy » Fri Jan 09, 2015 10:45 pm
1I1 wrote:If you fire through the full frame number and model code to me I should be able to confirm that for you in writing
Thanks Bud - have sent a PM.
Linesy
Postby Linesy » Fri Jan 09, 2015 10:55 pm
matt dunn wrote:If it has SRS it would probably be written on the sunvisor.
that it would fail, Well maybe, if there are no other protection system markings present (and theres not) and they assess the car as "non airbag" then the steering wheel shouldn't matter. But hey hind sight is always 20/20
but if you went with a steering wheel that never had an airbag it would have probably passed, Agreed - wouldn't be an issue - but haven't got one and he whipped it in on New Years Eve
Linesy
Postby RS13 » Sat Jan 10, 2015 10:59 am
Surely the lack of a dash airbag warning light would? Lack of fuse?
RS13
Postby 1I1 » Sat Jan 10, 2015 11:41 am
AE101 and early AE111 (amongst a heap of other cars) had mechanical airbags where there is no electronic side to the airbag setup so they had no light or fuse as theres no ECU.
TRD Clicky >>Here
1I1
Postby RS13 » Sat Jan 10, 2015 3:33 pm
Ah right, good to know.
RS13
Postby 1I1 » Sun Jan 11, 2015 12:27 am
Haven't struck it much lately but use to semi-regularly take calls from garages or people on the matter with WOF's on those cars. Would have an airbag wheel but no airbag light for the system check.
TRD Clicky >>Here
1I1
Postby Linesy » Sat Jan 24, 2015 8:03 pm
Big thanks to Mark for the support on this.
As it turns out this was a complete non event, get the right guy that knows the rules and it's easy.
Seems once a car is over 20yrs old airbags can be freely removed etc, so got the new wof piece of cake.
Thought the detail may help some one.
Linesy
Linesy
Postby Grrrrrrr! » Sat Jan 24, 2015 9:25 pm
You mean you found a guy that doesn't know the rules and it was a non-event. The rules are pretty clear, removal of airbags always requires a LVV cert, unless done for law enforcement or emergency services vehicles. Of course that doesn't apply if the car didn't have airbags when it left the factory.
Note 2
Some modifications are permitted, but they must always be LVV certified. The only modifications permitted are:
1. fitting a switch to render an airbag temporarily inoperable, and
2. the removal or permanent deactivation of an airbag in a vehicle that:
is at least 14 years old, or
has been adapted for a person with a disability, or
has been extensively modified for motorsport use.
Grrrrrrr!
Postby thegreatestben » Sun Jan 25, 2015 3:07 pm
I just read a newsletter that advises they are changing the rules around airbags on older vehicles.
thegreatestben
Postby ~SlideWays~ » Mon Jan 26, 2015 1:37 pm
thegreatestben wrote:I just read a newsletter that advises they are changing the rules around airbags on older vehicles.
I'd really like to know what happens here.
~SlideWays~
Postby Leon » Mon Jan 26, 2015 1:54 pm
Interesting, because so far as I'm aware LVVTA (where I work) isn't aware of this upcoming change.
(which is not to say that NZTA hasn't started something without telling us, heh)
Postby thegreatestben » Mon Jan 26, 2015 9:10 pm
I likely misinterpreted then.
thegreatestben
Postby Linesy » Tue Jan 27, 2015 7:43 pm
Grrrrrrr! wrote:You mean you found a guy that doesn't know the rules and it was a non-event. The rules are pretty clear, removal of airbags always requires a LVV cert, unless done for law enforcement or emergency services vehicles. Of course that doesn't apply if the car didn't have airbags when it left the factory.
Note 2
Well that is interesting, chap doing the recheck didn't make the decision in isolation.Went away with my story around the history of the car, discussed with others at the branch (assume even the boss) and came back claiming no drama - isn't an issue on vehicles over 20 yrs old. Bearing in mind this was not at a backyard estabishment!
Was certainly though on the rechecking of the other small items (seatbelt, windscreen etc) and issued the wof.
Feel like I've pulled the top off a can of worms............
Linesy
Postby Bling » Wed Jan 28, 2015 11:32 pm
Linesy wrote:Bearing in mind this was not at a backyard estabishment!
It was VTNZ though... :lol:
Postby Mr Ree » Fri Jan 30, 2015 9:58 am
Bahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahaha ^
wak thud gush!
Mr Ree
