Redlines
- Chickenman
- I Am The Walrus!
- Contact:
Redlines
Ok this is mostly so I can find out the factory redline of a st185 3sgte but be interesting to see where other Toyotas are supposedly heading for trouble.
1990 Corona = 6grand
Baby Jesus
92GTApex
- Toyspeed Member
20valve = 7600
cut out = 8300
3.8L commodore about 3500
Logan
cut out = 8300
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
www.area-51.co.nz
www.lextreme.com
- Snoozin
- Toyspeed Member
- Contact:
My 2K Starlet didn't have a rev counter, so I couldn't tell you what redline the mighty 2K had.... iirc it makes its whopping 45hp at around 5500rom, so I imagine redline isn't far past that!
Once I had 80km/h out of it, absolutely screaming it's nuts of in 2nd.
Alfa redlines at 6000rpm, but thats for the old 1.5l engine, the new 1700 redlines at 6500rpm, and makes maximum power at 6300rpm. Alfa tend to set fairly timid redlines on the tacho, but when I did have a rev limiter, (mechanical, centrifugal device in the dizzy rotor - now replaced by a Mk4 Cortina rotor without such a limiter) it cut in at 7200.
- Dell'Orto
- ** Moderator **
Factory redline is at 7 grand in the MR2, with factory rev cut at 7,200. Mine is currently at 2 grand
- Chickenman
- I Am The Walrus!
- Contact:
flygt4 wrote:gen 2 3sgte once again... red lined at 7...but wuld go all the way to 7800 b4 it hit limiter if u were silly enuf...... apparently they sposed to cut at 7200.... but mine had no speed cut either so go figure.ecu was stock coz i pulled it out and had a play with it too.
Same with my old factory ECU, no speed cut and no rpm limit (well none that i was game enough to find
90 Celica GTR Turbo
184kw @ 14psi at the front wheels (Now running 17psi watch this space for dyno
"Owner of the fastest Celica GTR in NZ (Until proved otherwise
www.Jools.tk
www.Jools.tk
- Dell'Orto
- ** Moderator **
Hmmm, perhaps the ST185's dont have cuts, as Garth (Al knows him
) reckoned his never cut out, but I dont think he ever tried to bounce it off the limiter.
ants_ae92 wrote:4age 16v 7200rpm. My model doesnt have a rev cut out or speed cut out. Found that it had no rev cut out on the dyno as the dude who drove it reved it to 8grand.
I think you'll find that all 4age's with std ECU will have a rev cut.
From memory they range from 8200 to 8600 though.
Matt
- Chickenman
- I Am The Walrus!
- Contact:
FYI The Gen III 3S-GTE can be takin up to 8000rpm due to its shim under bucket design so i've read, but you wouldnt be making stuff all power up there without mucking with the cams i'm guessing.
90 Celica GTR Turbo
www.Jools.tk
www.Jools.tk
- Rollux
- Toyspeed Member
Mate's worked 4k pulls to 9000 regularly(like, every gear change)
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
