fuel/boost cut on turbo SW20
Post Reply
GTSMR2TURBO
Post by GTSMR2TURBO »
how many lb's of boost before you hit the fuel cut ???
Current Ride - 1993 GTS MR2 (K&n pod, HKS bov, Toms Kit)
Post by Dell'Orto »
12.5psi
Al
Contact:
Post by Al »
Also, to disable the boost cut just pull the hose off the bottom of the boost pressure sensor (next to the grey box labelled diagnostic) and plug the hose up leaving the sensor open to the air
GTSMR2TURBO
So wat do they boost as standard ???
Al
Contact:
Post by Al »
Standard they are t/vsv controlled from 7->11.8psi
usually you should run 10-11ish
optimal conditions (up to temp, good quality fuel and cold intake air) will net max boost of 11.8
lazarus
Contact:
Post by lazarus »
Ok noob questions;D
whats t/vsv???
Al
Contact:
Post by Al »
turbo - variable solenoid valve
under optimal conditions it opens and bleeds air away from the actuator, so the turbo has to work harder to fix this 'leak' so it raises boost 3-4psi or so
its a factory boost controller
Post Reply
