4k Overheating
Post Reply
1goodidea
4k Overheating
Post by 1goodidea »
I've had this problem with both my starlets with both of their k-series motors, how do i stop the motor from over-heating if im stoped with the car running for a few minutes or at major traffic jams.
Radiator is in reasonbile condition, it's a stardard kp60 item with a few broken fins
any ideas, anyone else have this problem?
pervert
Post by pervert »
I've had a few K's, and never had any real overheating issues.
Is the radiator fan running at all?
Overheating in traffic sounds like it might not be.
Ae92typeX
Post by Ae92typeX »
things like correct fuel mixture and timeing also can contribute heaps to heating problems, although the radiator would be my first port of call.
Have you ever backflushed it?, even if it looks ok it could be clogged. Also as above, check the fan is operating too
dazzag
Post by dazzag »
also may want to check the thermostat isnt jammed
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
andyztouring
check
Post by andyztouring »
check that the fins (or propellor) hav`nt come off on the waterpump,this happened to my parent`s KE70,overheated the engine.
TygerTung
Post by TygerTung »
Yeah, is your radiator fan going?
I've NEVER had any problems with overheating in any of my K motor's, they usually run pretty cool actually.
I don't even have a fan on mine at the moment, and it only gets hot if you are sitting in one spot for like 5 or more minutes.
Post by Dell'Orto »
Mine only heats up in stop start traffic, but the radiator is pretty poked. Ordinarily its fine.
Hows the radiator cap too?
Rob
Post by Rob »
My 4K overheated when I tried to be a cheap arse and went from twin carb to single carb. (had big cam though)
Make sure yo got no vacuum leaks or manifold leaks
Other than that it should be sweet. Trust me you can't kill a "K" series engine with running it dry of water and oil at the same time!!!!!!!!!
Also check gaerbox level if you still worried. When my gt4 gearbox blew my engine over heated :wink:
1990 ST185H - project
1996 VS Acclaim wagon
1goodidea
Post by 1goodidea »
k thanks guys, fan works, cap sweet, fushed it out once i'll give that another go this weekened
AE85coupe
Contact:
Post by AE85coupe »
could be a blown head gasket....
AE85 Trueno *For sale*
Details of car here
Post Reply
