Race Fuel
EssDub
Race Fuel
Post by EssDub »
Here is a random question foir you all - How safe is Race Fuel on a standard engine? I've heard of it being used on the road and is apparently cleaner burning than a lot of pump fuels used around the country. What i want to find out is what differences or problems it could cause in an every-day-use motor :) I think the octane rating on it is around 100, but i'm not sure, does anybody know? cheers :)
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
trdfxgt
Post by trdfxgt »
its illegal to use race feul in road cars but its safe touse in just about all efi cars and alot of carbi ones 2 dependent on age
Monsterbishi
Contact:
Post by Monsterbishi »
It's got a ton of lead and benzine in it, so is far from clean burning, eventually it'll foul your o2 sensors, and will block up most catalytic converters too.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
EssDub
Post by EssDub »
I thought that was AVGAS? :?
Post by Leon »
You can get unleaded race fuel, but it's effin expensive.
"race gas" usually refers to leaded petrol, that is basically dated aviation fuel.
Post by Dell'Orto »
Yeah, proper race fuel is very expensive...well, actually compared to pump gas its pretty reasonable now :? I priced up a 20l drum of VP 103, and it was $110+
Thing is, you'd notice 3/8ths of $&#$% difference in an NA car, and more than likely would actually lose power, as it burns so much slower.
fangsport
Post by fangsport »
i beg to differ. i had a heap of WRC control fuel and it makes a huge difference in a N/A engine ,possibly 15% maybe more power.
Contact:
Post by Mr Revhead »
that FIA stuff sure stinks though!
and is not kind to seals and orings
fangsport
Post by fangsport »
Mr Revhead wrote:that FIA stuff sure stinks though!
yeah, it isn't recommended to leave it in some vehicles, as the hydrocarbons will attack any plastic/rubber components
Post by Leon »
Try being stuck in the Sky City carpark with all the cars queued up (idling) when they left in the mornings. I was there as a scrutineer, and I tell ya, I wasn't feeling too flash after a couple of hours of those fumes.
bad20v
Contact:
Post by bad20v »
Leon wrote:Try being stuck in the Sky City carpark with all the cars queued up (idling) when they left in the mornings. I was there as a scrutineer, and I tell ya, I wasn't feeling too flash after a couple of hours of those fumes.
Harden up man!! That stuff should be running through your veins by now!! :D
Thank-You.
Contact:
"that stuff" is a lot different fromt he stuff you will smell at ya local speedway/race track :?
Post by Dell'Orto »
Im sure you didnt use it in an average NA motor though did you :P
I think WRC fuel would probably be a bit different again to VP fuel, but I really have no idea.
I'd be very surprised if adding just race fuel gained you 15% power, unless you had very high compression and/or lots of advance.
fangsport
Post by fangsport »
Mmm, Boost wrote: I'd be very surprised if adding just race fuel gained you 15% power,.
the rally guys reckon that with the right program for the ecu, there can be an increase of up to 70hp in a group N car using the control fuel.
Mmm, Boost wrote: unless you had very high compression and/or lots of advance.
bit of both. bear in mind the old engine wasn't huge in power and was tired, but this fuel and a big carb and i reckon it was close to double at the wheels.
unfortunately ,one didn't check the fuel union on the carb, and an inferno followed.
Post by Dell'Orto »
But thats not just adding control fuel now is it ;)
Again, its hardly fair to compare a race motor to your average guy on the street...I know on the right application race fuel makes a big difference, but if I were to chuck some into the wagon, it'd do jack for it.
fangsport
Post by fangsport »
Mmm, Boost wrote: Again, its hardly fair to compare a race motor to your average guy on the street...I know on the right application race fuel makes a big difference, but if I were to chuck some into the wagon, it'd do jack for it.
but at least then you can advance the timing and make more power!!! :wink:
Monsterbishi
Contact:
Mmm, Boost wrote:But thats not just adding control fuel now is it ;)
Especially if your on the Toyota works team :-)
--- Cut Here ---
caldinagtt
Post by caldinagtt »
look at brett lee sangs evo 2 in the latest performance car rs on pump gas 23psi 340kws at the wheels and on c16 373 kw on 23psi atw now thats a big differnce so you do deinatly get a power gain.
CozmoNz
Contact:
Post by CozmoNz »
and how much of a timing increase?
if a 91 octane car makes 100hp, with no det, at say 5degree timin (whatever engine), what does it make on 98?
eg, 4efe starlet, will it make ANYmore power, with the same timing, with higher octane fuel? :)
Rayne For President!
Monsterbishi
Contact:
caldinagtt wrote:look at brett lee sangs evo 2 in the latest performance car rs on pump gas 23psi 340kws at the wheels and on c16 373 kw on 23psi atw now thats a big differnce so you do deinatly get a power gain.
CozmoNz wrote:and how much of a timing increase?
It's all in the timing, when our lifters decide to act up, the phantom knock pulls 20 degrees, when driving, it feels like a sock has been stuffed into the turbo, even though the boost level is the same.
--- Cut Here ---
Post Reply
