altezza clutch
altezza clutch
hey guys im in need of sum info on the clutch on my altezza
it's a 1998 rs200 3sge beams my release bearing is starting to rattle loudly on idle so im thinking i may as well replace the whole clutch
what i would like to know is
1 some people say you need to replace the flywheel as well is this true?
2 do you guys know of anyone that could give me a good deal on a
new clutch setup?
dylan
new clutch setup?
dylan
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
98 RS200 ALTEZZA
It's a dual mass fly wheel, you can turn the machined suface about 30 degrees by hand. It has all the springs and dampers in the flywheel insted of the clutch plate. There isn't really any way to hold the fly wheel to machine it because the ring gear and center aren't directly attached to the surface that needs to be machined.
The TRD fly wheel however is a normal type, with a sprung clutch plate.
[quote="Quint"]why the hell would they do that?
quote]
to make the clutch feel less ah brutal, its a kind of dampening thingy, S15 silvias have them too.
on my mates drift s13 (s15 engine + box) they just welded the rotating bit then machined it, cuz with the dual mass it wouldnt clutch kick as teh fly absorbed most of the shock. prob not the best way of doing it.
places like BNT sell a selected range of replacement flys
quote]
- Mr Revhead
- SECURITY!
- Contact:
HRT wrote:Hilux/Surfs are awesome for those flywheels stuffing themselves and getting noisy. Toyota do solid flywheels and clutch setups for them, surely they have a solid option for the Tezzas too?
Chances are it wont need one anyway, just chuck a kit at it
sort of.... a kit and flywheel from other models will fit
but theres no specific "dual mass to solid" kit.
and the same cant be done for the altezza as the flywheel is so deep.
best option is to fit a TRD one if you dont like the stock set up
