Head shave - 20v silvertop
Post Reply
Flannelman
formerly known as Affroman
Post by Flannelman »
Wishing to pump up the compression on a Silvertop.
Im aware of .8mm TRD gaskets and flat top pistons to give it a boost but how much can the head be plained before there comes complications in weakening the head?
ace_nz
Re: Head shave - 20v silvertop
Post by ace_nz »
Flannelman wrote:Wishing to pump up the compression on a Silvertop.
i've taken 2mm off with no issues. Will effect cam timing a bit though.
Post by cat007 »
How much clearance is there normally between the piston top and valves? Or are they already an interference engine?
Flannelman
Around 9mm with stock pistons and head gasket installed.
Stock silvertop is non-interference
ace_nz, cam timing can be fixed with adjustable cam gears?
ace_nz
Post by ace_nz »
yep, you can correct the timing with gears, but the inlet being vvt makes it a bit tuff.
CAMB01
Post by CAMB01 »
Yes adjustable cam gears will be needed to adjust the slack in the timing belt.
Ive taken 1mm off my block and the top of the pistons in my EVO to raise compression slightly. Had to grind a bit off the top of the engine mount and a bit off the back timing cover tins cause when i fitted the head they were holding it off the block.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
TRD_ZERO
Post by TRD_ZERO »
You cut up your pistons? Doesn't that mess with the integrity of the pistons?
Previous:
Boost_4_Life
Post by Boost_4_Life »
not if you use a good hacksaw.
The rally beast
The rally beast again!
TRD_ZERO
Post by TRD_ZERO »
Oh ok, just use pro tools and it's ok.
Previous:
Flannelman
removing material from pistons would lower the compression ratio...
skimming the block would bump it up
QikStarlie
Contact:
Post by QikStarlie »
i'd say he would have machined the pistons in the squish area, to avoid piston to head contact.
CAMB01
Post by CAMB01 »
Flannelman wrote:removing material from pistons would lower the compression ratio...
Not if you take material off the top to make the dish in the piston smaller.
All machining was done by me using a lathe and milling machine.
AceSniper
Post by AceSniper »
Still going to lower it, or you run longer rods to bring the pistons up higher?
CAMB01
Post by CAMB01 »
Hence why i decked the block to suit.
AceSniper
Post by AceSniper »
:D sorry my bad not reading complete story
Post Reply
