SR20 help
Post Reply
groupagt4
SR20 help
Post by groupagt4 »
Hi guys
Got a sr20de powered s14(manual). It keeps on dropping revs and dying when i come to a standstill. It runs fine under normal driving conditions, just dies as soon as I come to an intersection. I have checked the battery and alternater and they are both fine, any idea what it could be?
gt4dude
Post by gt4dude »
Vac leak? Idle control valve problem?? AFM problem?
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
groupagt4
Post by groupagt4 »
yea not sure, maybe vac leak. Would the other two throw a engine check light?
RS13
Post by RS13 »
I know I sound like a broken record with this, but have you run diagnostics?
DRFTIN
Post by DRFTIN »
does it backfire on gear shifts? mine is doing the stalling thing as well and i cant work out what it is. seems like a vacuum thing to me but no leaks i can find
groupagt4
Post by groupagt4 »
Not sure how to run the diagnostics. I have tried to do a bit of research but cant figure it out. It doesnt backfire or anything, just dies. It has a stupid aftermarket intake pipe and pod. There is a pipe coming from the cam cover that looks like it goes to the factory intake pipe, in this case it is just blocked off, could it be this?
ALES_AE111
Post by ALES_AE111 »
Hi mate,
I had the same issue in my old SR20 sentra. Kept stalling at inconvenient times and made traffic a real nightmare. I was advised that the O2 sensor was stuffed but didn't have a chance to test that out as the car caught fire.
Maybe a place to start? Mine was also running pretty rich and not very efficiently.
RS13
Post by RS13 »
CelicaGT8
Contact:
Post by CelicaGT8 »
BOV
tuff86
Post by tuff86 »
de is non turbo, sounds like inlet manifold leak...
Current: AE86 Corolla GT, Hyundai Veloster Turbo & Santa Fe
Previous: Lots of Toyotas and a few others
petrolhead
Post by petrolhead »
I have found this on quite a few cars i have driven with SR engines. Maybe stretched cam-chain kicking out cam angle sensor?
Hewies
Race and Restoration
3T-Rona
Post by 3T-Rona »
try cleaning out the throttle body
PM me for anything autoelectrical, Info or jobs etc....
Post by Adamal »
And give the AFM a good clean with some Co-contact cleaner. Make sure the TPS plug is clean too.
I had an issue with it hunting and revving too high at warm idle with mine, but can't quite remember what I did to fix it.... But check those out.
Post Reply
