How much does a turbo weigh?
Grrrrrrr!
Post by Grrrrrrr! »
Thinking about bringing a turbo back from Oz in a few months and wondering how much a turbo weighs? I just don't happen to have one lying about to weigh atm. If its <10kg I figure I can take some older clothing and ditch it before I fly back to save AUD$120 in excess baggage thievery.
Stott69
Post by Stott69 »
Will depend on turbo, the one I took off the car is lots lighter than the new one
Elmo
Post by Elmo »
VGT turbo from a 600 signature is about 50kg (at a guess)
Grrrrrrr!
Post by Grrrrrrr! »
So your 60-1 which the turbonetics website says is 15-20lbs was heavier than the Std turbo... guess a td05 should be in a similar ballpark then, plus weight of fittings/hoses etc. Will have to take the old steelcaps etc and ditch them before I return but should be doable.
Contact:
Post by iOnic »
I can weigh a td05hr/a if you want. Got a few.
Grrrrrrr!
Post by Grrrrrrr! »
Chur, that would be good man. Can preweigh and make sure its going to be under 23kgs.
Contact:
Post by iOnic »
Definitely is under that. My T88 weighs just on 15kg
Stott69
Post by Stott69 »
Grrrrrrr! wrote:So your 60-1 which the turbonetics website says is 15-20lbs was heavier than the Std turbo... guess a td05 should be in a similar ballpark then, plus weight of fittings/hoses etc. Will have to take the old steelcaps etc and ditch them before I return but should be doable.
Wasnt a standard, DSR430 slug. Still have the DSR at the mo if that weight suits your needs.
phoenix
Post by phoenix »
Just fashion it into a hat and save the luggage space.
Contact:
Post by Bling »
Glad it wasn't just me that thought of that :lol:
Post by rollaholic »
iOnic wrote:My T88
wtb pics of t88 on rb30
Lith
Post by Lith »
Atpturbo provide shipping weights for all of their turbos, which could give an idea of what you could expect : http://www.atpturbo.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=tp&Category_Code=GRT
2007 Mazdaspeed Axela
Jdawg
Post by Jdawg »
You can buy extra luggage allowance before you go.
Cost me NZ$60 for 40kg when I bought back a Commodore brake kit for the HZ = 20kg per side.
I went over in the clothes I was wearing and bought new clothes over there on my first day.
spoonza6
Post by spoonza6 »
Careful they might classify it as a dg n won't be allowed in checked luggage
Grrrrrrr!
Post by Grrrrrrr! »
Lol, good one :roll:
thegreatestben
Post by thegreatestben »
They almost didn't let me take a kingchrome socket set onto a domestic flight in my backpack, worried I'd take the plane apart midflight bahaha
Contact:
Post by iOnic »
Near as makes no difference to 10kg. Td05hra 16g with titanium compressor and 10.5cm rear housing.
CAMB01
Post by CAMB01 »
Friend of mine couldnt take some of his tools over to Aussie with him as he needed them for his job. They wouldnt allow them on board.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
Grrrrrrr!
Post by Grrrrrrr! »
Carry on is a no-go, checked should be fine. I've personally taken pinions, shims, hand tools, battery drills, various bearings, drill sets to Oz with no problem in checked luggage. Most trouble I had was with the shims and pinions, 28kg box of tightly packed stainless steel and high strength plastic gears. They xrayed it 5 times but they still couldn't see much, asked me what it was and seemed happy enough to let it fly once I told them.
I've actually been surprised at what I have got through security in carry on. had a couple of smallish screwdrivers in my laptop bag I'd forgotten about, and they had no problem with that. Would've been most useful if I'd wanted to stab someone..
CAMB01
Post by CAMB01 »
These were large 3/4 sockets etc. He's a diesel mechanic.
Post Reply
