1g-fe altezza idleing high
My sister has a 1g-fe powered altezza/is200. It is idleing high when in park and stationary at around 2500rpm-3000rpm. Is there any way of running a diagnosis check on it to get a falt code? Or would any one know what it could be?
Re: 1g-fe altezza idleing high
Is this from cold or once it should be warmed up? It could be the idle air control valve sticking from carbon build up
1990 ST185H - project
1996 VS Acclaim wagon
Im surprised Toyota used the 1G in such a late model vehicle - interesting.
The G-series engines are only 3 years older than the S-series.. the 1S first came out in 1982 over 1979 for the 1G. Did you know they made K-series engines up until 2007? Now THAT is more impressive..
late k series were all in forktrucks tho right?
Nope, Liteaces
- Dell'Orto
- ** Moderator **
And Kijang too!
