It's a "rocker" cover. I know saying rocket makes it sound like you'r car is gonna go fast but c'mon guys
Chickenman wrote:Could be worse dude, could slip in the shower and slice the end of your knob off on a rusty razor blade then knock over the dettol and fall into it![]()
Could be much, much worse.
IH8TEC wrote:yeah, used the whole can on it, lol, i personally think the photo makes it look better than it is, bu i'm picky, i stuffed the undercoat a bit, mint paint though, now jsut gota wait and see how it holds up to the heat.
Emperor wrote:I used the same paint (but red) and it turned out matt red and if you rub it enough it comes off
Emperor wrote:did exactly the same as we did on yours.
After driving around the heat's sort of baked it in, so it doesn't rub off everytime you touch it
SnakeEyes wrote:tomo1985 wrote:Silvertop Maybe?? Blacktop not a good idea i went down that path and everyone just said dont do it.
- Why? What's the actual difference between a Blacktop and a Silvertop?
K<^-^>E
