I got bored...
Postby Chickenman » Fri Feb 10, 2006 11:42 pm
Umm...
It's a "rocker" cover. I know saying rocket makes it sound like you'r car is gonna go fast but c'mon guys :roll:
Baby Jesus
Chickenman
I Am The Walrus!
Postby SnakeEyes » Fri Feb 10, 2006 11:44 pm
Chickenman wrote:Umm...
- wh00ps, my bad... :oops:
K<^-^>E
SnakeEyes
Postby Chickenman » Sat Feb 11, 2006 12:38 am
Could be worse dude, could slip in the shower and slice the end of your knob off on a rusty razor blade then knock over the dettol and fall into it :o
Could be much, much worse.
:D
Baby Jesus
Chickenman
I Am The Walrus!
Postby SnakeEyes » Sat Feb 11, 2006 12:43 am
Chickenman wrote:Could be worse dude, could slip in the shower and slice the end of your knob off on a rusty razor blade then knock over the dettol and fall into it :o
:D
- Oh THANKS ALOT for that! I always shave in the shower, you know! :P
K<^-^>E
SnakeEyes
Postby Emperor » Sat Feb 11, 2006 12:44 am
:lol:
Emperor
Postby 86_rolla » Sat Feb 11, 2006 7:52 am
:D
Hahaahha classic
Current: EF Honda civic
Ex cars: 2E corolla
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1488
86_rolla
Postby 20v_rollaboy » Sat Feb 11, 2006 8:16 am
Well back on topic, my rolla had a 4afe in it, and as you can see it now has a 20v silvertop. I would have gone for the black top but at the time I ddnt have ehough money. So if you do go the black top!!!
As for fitting the engine, it will bolt straight in. 4afe gearbox will bolt on to it, wiring in the engine bay will plug in aswell, just get the wireloom with the engine and the fuse box. Then you just have to worry bout the two plugs under the dash. Oh yea and get the exhaust from the 20v if you can, its much better than the 4afe one.
20v_rollaboy
Postby SnakeEyes » Sun Feb 12, 2006 11:02 am
Thanks dude, I'll certainly look into it when I get some cash ^_^
K<^-^>E
SnakeEyes
Postby IH8TEC » Sun Feb 12, 2006 5:08 pm
:lol:
i got bored today too, now i better study
Postby SnakeEyes » Sun Feb 12, 2006 9:19 pm
That's a mint job, dude. What paint did you use? Same stuff as me?
K<^-^>E
SnakeEyes
Postby IH8TEC » Sun Feb 12, 2006 10:02 pm
yeah, used the whole can on it, lol, i personally think the photo makes it look better than it is, bu i'm picky, i stuffed the undercoat a bit, mint paint though, now jsut gota wait and see how it holds up to the heat.
Postby Emperor » Sun Feb 12, 2006 10:05 pm
I used the same paint (but red) and it turned out matt red and if you rub it enough it comes off :?
Emperor
Postby no_8wire » Sun Feb 12, 2006 10:46 pm
woot woot go the carbon pod shield!
no_8wire
Postby SnakeEyes » Sun Feb 12, 2006 11:48 pm
IH8TEC wrote:yeah, used the whole can on it, lol, i personally think the photo makes it look better than it is, bu i'm picky, i stuffed the undercoat a bit, mint paint though, now jsut gota wait and see how it holds up to the heat.
- I've been driving around a lot and the paint's holding up fine on mine. Even retouched the tip of my exhaust, which was originally blue, until I drove to Auckland one day and practically burned the blue finish off the tip months ago :lol:
K<^-^>E
SnakeEyes
Postby SnakeEyes » Sun Feb 12, 2006 11:50 pm
Emperor wrote:I used the same paint (but red) and it turned out matt red and if you rub it enough it comes off :?
- Did you sand it down (if it needed it) and use the ground coat stuff first, or just attack it with the red paint?
K<^-^>E
SnakeEyes
Postby Emperor » Sun Feb 12, 2006 11:53 pm
did exactly the same as we did on yours.
After driving around the heat's sort of baked it in, so it doesn't rub off everytime you touch it
Emperor
Postby SnakeEyes » Sun Feb 12, 2006 11:58 pm
Emperor wrote:did exactly the same as we did on yours.
- Sweet as then, glad it came right in the end ^_^
K<^-^>E
SnakeEyes
Postby tomo1985 » Mon Feb 13, 2006 9:01 am
Silvertop Maybe?? Blacktop not a good idea i went down that path and everyone just said dont do it.
tomo1985
Postby SnakeEyes » Mon Feb 13, 2006 10:12 am
tomo1985 wrote:Silvertop Maybe?? Blacktop not a good idea i went down that path and everyone just said dont do it.
- Why? What's the actual difference between a Blacktop and a Silvertop?
K<^-^>E
SnakeEyes
Postby JT » Mon Feb 13, 2006 11:32 am
K<^-^>E
I doubt the people that told tomo1985 know the differences either, if they did they wouldn't have sugested a silvertop over blacktop. Unless you plan on going turbo, get a blacktop.
Have a read of the FAQ section, here's the 4age section in there:
viewtopic.php?t=29061
JT
