My mate wants to build a reeeely fast ute
Postby barryogen » Tue Mar 14, 2006 8:29 am
jeda teach wrote:im just tryna get help for him.
heh, help is needed "closer to home"
barryogen
2ZZ Guru in training
Postby Ako » Tue Mar 14, 2006 9:14 am
I thought the beauty of the 2JZ is that it IS possible to be pulling big numbers on a stock-ish engine?
Switching cams isn't what I'd call "opening the engine up", so thats not an issue, and the net is filled with articles on internally stock (bar cams) 2JZ's putting out big numbers.
My vote - Don't stuff around with the ute idea. Find yourself an already built chassis, minue engine and box, and use that. You might even get lucky and find a ute built for the purpose up for sale. That way you get the benefits of a car which has already had teething issues sorted, and you're likely to get it for around 1/3 of the actual build cost.
Our drag car here at work has so far cost approx $40K, and its aiming for an 8 next time it goes out. And thats a dirty horrible 20B, I'd say the 2JZ would be about the same to pull numbers out of. Drag racing doesn't have to be ridiculously expensive if you do it intelligently, and have a clear goal from the outset. Not "12's or maybe 9's" - aim for a target, and build the car to achieve it.
Say you coax 600hp out of the engine - which to be honest isn't that extreme an ask for the 2J - and put it into a chassis weighing under 1000kgs, bam - there's your 10 second pass without breaking a sweat. The numbers are easy to work - its just the $$ numbers coming out of your wallet that will hold things back. Talk to as many ACTUAL experts as you can, and if you're genuinely serious then they'll help you out.
Ako
Postby Dragger_Dan » Tue Mar 14, 2006 9:18 am
Look at the Kiwi RE Sylvia for how to do a drag car on the cheap.
Dragger_Dan
Postby Chickenman » Tue Mar 14, 2006 9:47 am
Edit cos I'm stupid.. read it below though :roll: :oops:
Baby Jesus
Chickenman
I Am The Walrus!
Postby wde_bdy » Tue Mar 14, 2006 10:22 am
wde_bdy
Postby jeda teach » Tue Mar 14, 2006 10:29 am
Ako wrote:I thought the beauty of the 2JZ is that it IS possible to be pulling big numbers on a stock-ish engine?
thanks for your comments, they arnt gonna do the ute now i think cause its gonna cost to much, im not sure. I was just tryna get ideas.
jeda teach
Postby Silent Knight » Tue Mar 14, 2006 10:33 am
jeda teach wrote:thanks for your comments, they arnt gonna do the ute now i think cause its gonna cost to much, im not sure. I was just tryna get ideas.
No offence here but I think that if you need to come on to a forum to find out that a project like this is going to cost you too much and that a stock tranny aint going to do it etc. you really shouldn't be attempting a project like this at all.... :?
Silent Knight
Postby Chickenman » Tue Mar 14, 2006 10:35 am
purple_beasty wrote:The truth
Sorry dude, I assumed a little too much there.
What about cage regulations or can you get anything you want certed for road use?
Baby Jesus
Chickenman
I Am The Walrus!
Postby mr pad » Tue Mar 14, 2006 10:43 am
Way I see it, the man asked a few questions based on what knowledge he had, even if it wasn't much...
Ok so it cant be done, everone need to jump on the bandwagon and flame the shit out of him? Forums suck.
mr pad
Postby Silent Knight » Tue Mar 14, 2006 10:43 am
Chickenman wrote:What about cage regulations or can you get anything you want certed for road use?
AFAIK you can get a half cage certified for road use but not a full cage unless it's a bolt on cage which you can unbolt as the sidebeams will not be safe to have in case of a crash.
By that I mean it will make it harder for the driver/passenger to exit the car the that in place so they deem it to not be roadworthy.
Silent Knight
Postby wde_bdy » Tue Mar 14, 2006 1:18 pm
wde_bdy
Postby Leon » Tue Mar 14, 2006 1:43 pm
Couldn't be done through Motorsport NZ for a drag car.
Postby fangsport » Tue Mar 14, 2006 3:09 pm
Leon wrote:Couldn't be done through Motorsport NZ for a drag car.
even if the cage followed MSNZ details and the car was used twice for MSNZ permitted events?
fangsport
Postby wde_bdy » Wed Mar 15, 2006 12:32 pm
wde_bdy
Postby the fallen303 » Wed Mar 15, 2006 1:46 pm
i heard somewhere that they're proposing running one type of cage that can be used for drag/track/rally, as there are getting more multi purpose cars now? like evo's, etc, that can run very quick on drag, then few changes, and out on circuit. anyone heard anything about this?
true house of JZ
Stay true to the origin
the fallen303
Postby bad20v » Wed Mar 15, 2006 2:45 pm
MY....Image
Thank-you. Please come again.
8)
Thank-You.
bad20v
Postby fangsport » Wed Mar 15, 2006 4:17 pm
the fallen303 wrote:i heard somewhere that they're proposing running one type of cage that can be used for drag/track/rally, as there are getting more multi purpose cars now? like evo's, etc, that can run very quick on drag, then few changes, and out on circuit. anyone heard anything about this?
the cages for circuit and rally are already the same specs as both are governed by MSNZ. in fact, a Group N rally car and a production racing are essentially the same vehicles with different tyres and suspension settings. likewise a regional rally car and a Super GT/ Sports Saloon.
fangsport
Postby Leon » Wed Mar 15, 2006 4:56 pm
Yep.
Then it wouldn't be a drag car :)
Postby Leon » Wed Mar 15, 2006 4:57 pm
er ... well my job is homologating race / rally cars ... and I know nothing of this "they" you are speaking of. So that'd be a no.
Postby Ako » Wed Mar 15, 2006 5:23 pm
Well, its a damn good idea for it to be looked into. As some have mentioned, there's a few cars floating about which while being circuit or drag cars primarily, are quite capable of performing in the other arena.
Ako
Users browsing this forum: No registered users and 44 guests
