jeda teach wrote:im just tryna get help for him.
heh, help is needed "closer to home"
Ako wrote:I thought the beauty of the 2JZ is that it IS possible to be pulling big numbers on a stock-ish engine?
Switching cams isn't what I'd call "opening the engine up", so thats not an issue, and the net is filled with articles on internally stock (bar cams) 2JZ's putting out big numbers.
My vote - Don't stuff around with the ute idea. Find yourself an already built chassis, minue engine and box, and use that. You might even get lucky and find a ute built for the purpose up for sale. That way you get the benefits of a car which has already had teething issues sorted, and you're likely to get it for around 1/3 of the actual build cost.
Our drag car here at work has so far cost approx $40K, and its aiming for an 8 next time it goes out. And thats a dirty horrible 20B, I'd say the 2JZ would be about the same to pull numbers out of. Drag racing doesn't have to be ridiculously expensive if you do it intelligently, and have a clear goal from the outset. Not "12's or maybe 9's" - aim for a target, and build the car to achieve it.
Say you coax 600hp out of the engine - which to be honest isn't that extreme an ask for the 2J - and put it into a chassis weighing under 1000kgs, bam - there's your 10 second pass without breaking a sweat. The numbers are easy to work - its just the $$ numbers coming out of your wallet that will hold things back. Talk to as many ACTUAL experts as you can, and if you're genuinely serious then they'll help you out.
jeda teach wrote:thanks for your comments, they arnt gonna do the ute now i think cause its gonna cost to much, im not sure. I was just tryna get ideas.
purple_beasty wrote:The truth
Chickenman wrote:What about cage regulations or can you get anything you want certed for road use?
even if the cage followed MSNZ details and the car was used twice for MSNZ permitted events?Leon wrote:Couldn't be done through Motorsport NZ for a drag car.
the cages for circuit and rally are already the same specs as both are governed by MSNZ. in fact, a Group N rally car and a production racing are essentially the same vehicles with different tyres and suspension settings. likewise a regional rally car and a Super GT/ Sports Saloon.the fallen303 wrote:i heard somewhere that they're proposing running one type of cage that can be used for drag/track/rally, as there are getting more multi purpose cars now? like evo's, etc, that can run very quick on drag, then few changes, and out on circuit. anyone heard anything about this?
Users browsing this forum: Bing [Bot] and 23 guests
