20v Trumpet Question
Postby Caribeena » Fri Jul 27, 2007 11:39 pm
Tried a search but didn't come up with any answers,
When people have taken their plenums off on a 20v and run open trumpets, what has been done with the vacuum pipes running off the factory plenum and also the air intake temp sensor?
Im not planning on doing this anytime soon, but am just curios
Caribeena
Postby Crampy » Fri Jul 27, 2007 11:53 pm
I was using open throttles with aftermarket trumpets. Just put the sensor next to the inlet of the trumpets. For the vacuum lines, I just put a little filter on them.
I was going to put in a bonnet scoop at some stage as well, so it had a cold air feed rather than sucking the hot air form the engine bay. Ended up selling my BZ-G before I could be bothered though.
This was on a Blacktop, you can't do that with a Silvertop if using the stock computer, due to needing the AFM.
Crampy
Postby Matty104 » Sat Jul 28, 2007 1:31 pm
Crampy wrote:I was using open throttles with aftermarket trumpets. Just put the sensor next to the inlet of the trumpets. For the vacuum lines, I just put a little filter on them.
what size trumpets did u use? was going to make some stainless ones up for my blacktop
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Crampy » Sun Jul 29, 2007 2:28 pm
I got my ones off Trademe. They were 70mm long. They weren't the best though, as they didn't quite have the same size as the mating surface on the throttles, so they probably weren't the best for outright flow.
If you're going to amke your own though, you'll be sweet. I'd say to make them around 70mm to 100mm long.
Crampy
Postby Matty104 » Sun Jul 29, 2007 2:48 pm
does m aking them out of 2" (50mm) pipe sound about rite? is it just get rid of all the factory box and rubber trumpets and bolt then strait onto there?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Crampy » Sun Jul 29, 2007 3:20 pm
Yeha just unbolt box and old trumpets and chuck the new ones on.
As for making out of 50mm pipe, no no no!
Trumpets need to be tapered and have a bell mouth at the end to be fully effective, otherwise you'd probably be better off just using the original trumpets. You'll be going backwards in power with straight 50mm pipe.
Measure the throttle opening with the trumpet off and that's the size you'll need to taper down too.
Before I got my aftermarket trumpets, I had the original ones on it, withour the intake box and some socks filters on them. That sounds insane. I love the sound of open individual throttles.
Crampy
Postby Caribeena » Tue Jul 31, 2007 9:12 pm
yeah i had mine off for a bit! insane! whered you get the filter sox from? i found some for $200 for 4, just want to see if theres any cheeper.
Caribeena
Postby gasman » Tue Jul 31, 2007 9:18 pm
Caribeena wrote:yeah i had mine off for a bit! insane! whered you get the filter sox from? i found some for $200 for 4, just want to see if theres any cheeper.
buy mine here
pics here
needs a bit of a clean and the zipties are even special ones where they have a tab to release them so you can use them again.
"What can possibly go wrong?"
gasman
Postby Caribeena » Tue Jul 31, 2007 9:32 pm
pm sent
Caribeena
Postby nz_climber » Tue Jul 31, 2007 10:00 pm
Don't know how true it is, but a lot of places I have read on the internet say that filter socks over individual trumpets mess up the airflow entering the trumpet, and recommend a fully enclosed filter. As to get max flow and undisrupted flow a trumpet needs about 15-20mm between the bell end and any air filter.
I don't have trumpets on my 45mm carbs yet, but got an itg foam air filter for so that I can fit a trumpets at a later stage.
http://www.itgairfilters.com/content2.asp?section=megaflow
nz_climber
Postby Matty104 » Tue Jul 31, 2007 10:02 pm
gasman,
do u reckon you could put a pic of the trumpets up without the filters on?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby gasman » Tue Jul 31, 2007 10:09 pm
Matty104 wrote:gasman,
the engine is in wellington with my brother so ill tell him to take a pic of them asap.
gasman
Postby gasman » Tue Jul 31, 2007 10:10 pm
also has a 5 degree taper and is semi polished on the inside (i did the best i could) but not on the outside on 3 of them coz i cbf
gasman
Postby Bling » Tue Jul 31, 2007 11:54 pm
nz_climber wrote:Don't know how true it is, but a lot of places I have read on the internet say that filter socks over individual trumpets mess up the airflow entering the trumpet, and recommend a fully enclosed filter. As to get max flow and undisrupted flow a trumpet needs about 15-20mm between the bell end and any air filter.
The filter socks I used to use had internal springs so the end of the filter sits around 50mm from the end of the trumpet, never had any issues.
Postby frost » Tue Jul 31, 2007 11:59 pm
pm me if your interested in a set of these
Postby Logan » Wed Aug 01, 2007 9:12 am
any ony got any before after dyno runs for different trumpets?
SR Sold. Onto Other Things
Logan
Postby Crampy » Wed Aug 01, 2007 11:21 am
Here's mine. No dyno plots or anything.
I think it would have been better having them in a big single box with a filter on the top and my bonnet scoop feeding it. I sold the car before getting any of this done though.
Crampy
Postby QikStarlie » Wed Aug 01, 2007 5:40 pm
most of the air is drawn in from the sides not the top. thats the problem.
air box, variable trumpets and 16 vavles! is where its at :D
QikStarlie
Postby Crampy » Wed Aug 01, 2007 5:45 pm
Damn those are nice!!!
Crampy
Postby matt dunn » Wed Aug 01, 2007 8:02 pm
Interesting stuff.
Dad's building my new intake off what he learnt with the V8SC guys.
a lot of the air actually comes from behind the trumpet,
flow around the side and into the trumpet so they need to stick out into the box a wee way.
Wouldn't have thought that myself but.........?
Millions of people, millions of idea's......
Users browsing this forum: Bing [Bot] and 22 guests
