ngk sparkplugs
Postby GT101 » Fri Mar 05, 2010 2:08 pm
ha crack up
i found no problems withe the two fram filters i used, but ive only used the repco ones before that so not much to compare them to.
whats the other option other than ripco filters?
i change the oil every two months on the 20v
current :project cynos version 2
previous toyotas :93 ae101 sprinter gt sedan 20v, 93 gt starlet,el44 cynos alpha,ae101 trueno.....
GT101
Postby Mad Murphy » Fri Mar 05, 2010 3:33 pm
Mr Revhead wrote:
Mad Murphy wrote:
Burning Angel wrote:cant get them fram filters no more,
they were so sh*t that Supercheap and BNT stopped stocking them and now stock GUD(Ryco) Also Supercheap don't do Bosch plugs anymore, gone to NGK.
I would second the shittiness of fram filters. Took one off this morning and it spilled oil everywhere, didn't seem to be draining back out of the filter. How good are the Ryco filters? I just put one on.
thats the way its meant to be!
I didn't quite explain myself right, needless to say despite draining oil from the engine first oil poured everywhere and went all over the floor when I took the filter off, I've never had this problem before with the same car (or other cars). I'd also noticed oil pressure randomly dropping the last couple of days. wasted a perfectly good dirty, mouldy towel wiping it up…
1989 Supercharged AW11, 1981 Sprinter GT, 1991 Primera s**tmobile.
Facelift AW11 Parts Wanted!
Mad Murphy
Postby Mr Revhead » Fri Mar 05, 2010 3:39 pm
Um, yeah thats the way it's supposed to be....
Anti drain back valve prevents the filter emptying of oil whilst engine is switched off. So when you remove the filter there should always still be oil in part of it.
Hard pressed to think of many cars where you won't spill some oil when removing the filter. Back in my Lube bitch days I made all sorts of containers to fit in certain cars to catch spillage
Postby Boosted_162 » Fri Mar 05, 2010 3:42 pm
GT101 wrote:ha crack up
Other option is probably the best one....TGP. Not overly expensive either.
Postby Mad Murphy » Fri Mar 05, 2010 3:55 pm
Mr Revhead wrote:Um, yeah thats the way it's supposed to be....
I'm just talking a lot more oil spillage than there'd normally be. Maybe I just accidentally tipped it while taking it out, kinda hard to see on an MR2.
Mad Murphy
Postby callum » Fri Mar 05, 2010 4:05 pm
Repco in morrinsville are useless. I work on my cars mainly in morrinsville but still try to avoid going there if I can. It's just to fustrating.
callum
Postby Nuty|Mike » Mon Mar 08, 2010 1:54 pm
back on the subject of spark plugs anyone know the standard equivallent of pzfr6f-11 cant find any crossover here
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby Mr Revhead » Mon Mar 08, 2010 2:01 pm
according to google that is the standard plug.....
http://www.spark-plugs.co.uk/pages/tech ... umxref.htm
Postby Burning Angel » Mon Mar 08, 2010 2:28 pm
Nuty|Mike wrote:back on the subject of spark plugs anyone know the standard equivallent of pzfr6f-11 cant find any crossover here
it would be a zfr6f-11 but im not sure if you can get them,
p= platinum,
z= extended gap,
f= ø 14, 19mm (3/4”) Reach, 16mm (5/8”) Hex.,
r= resistor,
6= heat range,
f=tapered seat,
11= 1.1mm gap
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Nuty|Mike » Mon Mar 08, 2010 2:35 pm
yea standard platnum or iridium only :( oh well
Nuty|Mike
