ha crack up
i found no problems withe the two fram filters i used, but ive only used the repco ones before that so not much to compare them to.
whats the other option other than ripco filters?
i change the oil every two months on the 20v
Mr Revhead wrote:Mad Murphy wrote:Burning Angel wrote:cant get them fram filters no more,
they were so sh*t that Supercheap and BNT stopped stocking them and now stock GUD(Ryco) Also Supercheap don't do Bosch plugs anymore, gone to NGK.
I would second the shittiness of fram filters. Took one off this morning and it spilled oil everywhere, didn't seem to be draining back out of the filter. How good are the Ryco filters? I just put one on.
thats the way its meant to be!
GT101 wrote:ha crack up
Mr Revhead wrote:Um, yeah thats the way it's supposed to be....
Anti drain back valve prevents the filter emptying of oil whilst engine is switched off. So when you remove the filter there should always still be oil in part of it.
Hard pressed to think of many cars where you won't spill some oil when removing the filter. Back in my Lube bitch days I made all sorts of containers to fit in certain cars to catch spillage
Nuty|Mike wrote:back on the subject of spark plugs anyone know the standard equivallent of pzfr6f-11 cant find any crossover here
