Fuel tanks
Postby Akane » Thu Oct 28, 2010 3:11 pm
Do you let the pump automagically stop pumping and it reaches 29 litres?
Or do you keep filling very slowly but manually after it automagically stops the pump?
Could bhe the air pressure trigger thingee majig that's broken and sense a fake pulse thingee to the pump and it's stopping way earlier than it should.
Try fill it slowly once the pump stops and see if you can go right up to the brim.
Postby tsoob » Thu Oct 28, 2010 4:26 pm
Akane wrote:Do you let the pump automagically stop pumping and it reaches 29 litres?
yeah thats possible, but its been like that on the last 6 fills and at different pumps.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby allencr » Thu Oct 28, 2010 5:05 pm
Is your tank anything like the AE86 that has almost 1/4 of its volume above the filler pipe, so that it needs a small tube inside its filler, positioned just right, to give the trapped air bubble a pathway out?
If that little tube isn't free of fuel, it doesn't work.
allencr
Postby piw » Thu Oct 28, 2010 5:58 pm
tsoob wrote:ITS NOT THE GAUGE!!!! I DON'T HAVE A GAUGE!!!!!!!!!!! AT ALL!!!!!
JUST COS IT SURGES DOESN"T MEAN IT'S EMPTY !!!
piw
Postby postfach » Thu Oct 28, 2010 6:39 pm
My car did the same thing when it wasn't empty, not as bad though. I never fixed it cos I'm lazy but since I first noticed it after putting in a new fuel pump I'm sure it was because the pump wasn't sitting low enough in the tank. I'd check that.
postfach
Postby tsoob » Thu Oct 28, 2010 7:40 pm
mate its empty. i know my car better than anyone, its def a low fuel pressure problem, im looking towards the pump not being in the right place.
I do wonder about this air lock thing tho...
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Truenotch » Thu Oct 28, 2010 7:46 pm
It's probably still got ten litres in there but just not sucking it up properly. I'd make sure that the pump is in the right place and go from there...
It won't have a 30 litre tank.
Truenotch
Postby matt dunn » Fri Oct 29, 2010 7:10 pm
tsoob wrote:its def a low fuel pressure problem..
Low fuel pressure and low fuel level are not the same thing.
Have seen cars run out of fuel with 1/2 a tank left due to incorrect fuel pump fitting,
and my car won't surge until it has less than 250ml's in the tank.
Postby BZG Wagon » Fri Oct 29, 2010 9:07 pm
tsoob wrote:what happens is the fuel gets down and the pressure drops and the car splutters.
Try a new fuel filter.
IMO:
1) Run it dry
2) Put in a few litres to get it to the station (carry a small can in your car)
3) See how much it takes to fill (just out of interest)
4) Replace your fuel filter ($40)
BZG Wagon
Postby tsoob » Fri Oct 29, 2010 9:46 pm
IMO:
1) Run it dry
I think ill look at the pump install first,
A new filter is prolly a good idea 2.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby tsoob » Wed Dec 08, 2010 1:13 pm
Ok so the tank was getting close to empty.. as in the pump is noisy and it looses pressure as described earlier in this thread.
I dropped the fuel out and got around 12-14 litres out of it (a bucket and a half)
I removed the pump (ill post a pic) but its still mounted in pretty much the exact same place as the factory one, the pickup is slightly facing upwards so i bent it down wards but yeah it dont make sense ay..
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby tsoob » Wed Dec 08, 2010 1:18 pm
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Quirky » Wed Dec 08, 2010 1:34 pm
Do you have to drop the tank to remove the fuel pump?
Hello There
Quirky
Postby tsoob » Wed Dec 08, 2010 2:04 pm
yep its a c**t.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Quirky » Wed Dec 08, 2010 2:13 pm
So thats why work shops are quoting me $500 for the job.
3 different workshops each the exact same price.
Hello There
Quirky
Postby Bazda » Wed Dec 08, 2010 2:49 pm
$500 is a bit off, I can take the tank out in 30 mins or less.
Postby tsoob » Wed Dec 08, 2010 2:52 pm
Bazda wrote:$500 is a bit off, I can take the tank out in 30 mins or less.
yeah it dont take 2 long ay..
yo baz any ideas from these photos??
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby sergei » Wed Dec 08, 2010 3:51 pm
I can see straight away that the bracket is lower than pickup.
can you modify fitment so the sock is lowest part of the pump?
Postby Quirky » Wed Dec 08, 2010 4:41 pm
Sorry thats $500 including run on the dyno to check AFRs.
Apologize for my unrelated questions, but can you drop the tank with the car on the ground?
Hello There
Quirky
Postby tsoob » Wed Dec 08, 2010 5:01 pm
yes, but its easier from underneath. (as in on the hoist)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
