Akane wrote:Do you let the pump automagically stop pumping and it reaches 29 litres?
Or do you keep filling very slowly but manually after it automagically stops the pump?
Could bhe the air pressure trigger thingee majig that's broken and sense a fake pulse thingee to the pump and it's stopping way earlier than it should.
Try fill it slowly once the pump stops and see if you can go right up to the brim.
piw wrote:tsoob wrote:ITS NOT THE GAUGE!!!! I DON'T HAVE A GAUGE!!!!!!!!!!! AT ALL!!!!!
JUST COS IT SURGES DOESN"T MEAN IT'S EMPTY !!!
tsoob wrote:its def a low fuel pressure problem..
tsoob wrote:what happens is the fuel gets down and the pressure drops and the car splutters.
BZG Wagon wrote:tsoob wrote:what happens is the fuel gets down and the pressure drops and the car splutters.
Try a new fuel filter.
IMO:
1) Run it dry
2) Put in a few litres to get it to the station (carry a small can in your car)
3) See how much it takes to fill (just out of interest)
4) Replace your fuel filter ($40)
Bazda wrote:$500 is a bit off, I can take the tank out in 30 mins or less.
Quirky wrote:Bazda wrote:$500 is a bit off, I can take the tank out in 30 mins or less.
Sorry thats $500 including run on the dyno to check AFRs.
Apologize for my unrelated questions, but can you drop the tank with the car on the ground?
